Question about Manitowoc Refrigerators
Model #BD0603W. ICEMACHINE COMPLETLY SHUTS DOWN AFTER HARVEST
  • 8,220 Answers
It could be a faulty Bin switch OR the water curtain not returning to freeze position.
B model tech manual
Posted on May 24, 2011
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scottman cu3030 max harvest-retrying, flashing code #2
The machine will try to harvest 3 times before it shuts the machine down. Is the ice thick enough to open the curtain door? if the curtain dose not open the magnet switch then the machine dose not know it has harvested the ice and will keep trying to harvest. Is the ice coming off the evaporator plate during harvest or is it hung on the plate? if hanging on the plate then system needs to be cleaned. is the harvest assist plunger working?
Oct 30, 2013 | Scotsman Refrigerators
I have a MV450 icemachine that work for up to 4 days without any problem .Then it cuts out the hi pressure indicator light up .i have checked the gas charge and cleaned the condensor
The magnetic switch just lets the machine know it finished a harvest and start ice production all over again. high pressure could be a dirty coil, fan motor stops working, a possible refrigerant restriction, or the room that the machine is in is getting to hot but this would cause the production of ice to take longer. it should be making ice every 15 to 18 mints in a 74 deg room.
Oct 05, 2013 | Scotsman Cooled Modular Contour Cuber Air...
I have a hoshizaki ice machine and it will harvest for about 3 harvest and just before the 3 harvest it shuts off. It makes us up untill it shuts off. It beeps 3 times. DONT know what to do! NEED SOME...
How long is a freeze cycle on your unit? How big are the cubes that it's dropping? The three beep error indicates that the unit exceeded maximum freeze time.
Sep 05, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Scotsman icemachine cm506 stuck in harvest hot gas won't close any ideas?
check for power to valve coil. If it remains it's a control problem. If no power and still in harvest, valve is stuck. Unit usually does not exceed a 6 to 8 minute harvest.
Aug 17, 2010 | Scotsman Cooled Modular Contour Cuber...
Icemachine is going into harvest prematurely.Why is this happening?
the grate under the evap plates have been known to break off small pieces. These pieces get caught in the discharge of the pump and hold open a spring loaded valve which then let water out and tricks the float into a harvest.
It's the white triangle piece with 3 screws in it usually just about or next to the pump. Look for broken pieces inside of it. Remember, when you take it apart, it's spring loaded.
Aug 04, 2010 | Hoshizaki KM-630M Crescent Cuber Ice Maker
CME500 ICEMACHINE MAKES ON BOTTOM PART OF CUBER ONLY
Hi!!!Relax you just answer your question.If you went and advance the timer and it work but was stuck in the same position well its your bad timer.change timer and you will be fine..Good luck
Jan 05, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Refrigerators Logo
173 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
