"Error 1068 Could not start the Printer Spooler on local Computer"
Hiya, I've recently had a problem with my printer, when I try to print something, it says I don't have one installed. I've tried to reinstall my printer, but when I try to uninstall it, it comes up with the error message "Processing cannot be continued because the printer spooler service has been stopped. Restart the system to start the printer spooler service, then try again" My Printer Spooler is definity at Automatic, because I already phoned them and my settings seemed to be correct. However, when i try to start the printer spooler the error message of: "Error 1068 Could not start the Printer Spooler on local Computer" comes up. will someone try help me resolve my problem? thanks very much :o) just purchased a new hp computer. tried to install my old Lexmark printer on it and just got spooler 1068 messages. So I bought a new hp printer thinking it may be compatable, but I am still unable to install. still same spooler errors. Spent hours online with chat techs running through every possible fix. Unable to get the spooler running.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
** Spooler Issue Fixed **
I got my problem solved help of this follwoing article please click below and follow there mentioned steps and get your problem
fixed.
Click here to open solved Solution for this problem Spooler not working (Solved)
http://www.techsupportall.com/print-spooler-is-not-running/
Posted on Mar 08, 2013
How do i fix my spooler so I can add my printer without having to buy some expensive software.
Posted on Mar 22, 2009
I have same problem
Posted on Jan 03, 2009
Hi i have aprob my computer say the printer spooler cannot running error 1068
Check for other Service Dependencies A 1068 is a service dependency error. Print Spooler can't start because it thinks a service it depends on is not running.
shortcut: start-run-"services.msc"
Go into services and check its dependencies, it should just be the RPC service, which you shouldn't be able to stop, check that RPC is running
Double click print spooler and click the dependencies tab. See if there are any other dependencies set besides rpc. If so you will want to find them in services and make sure they are set to automatic and are running (will probably need to start them).
Then try to start "Print Spooler" service, should work. May need to reinstall printer drivers then.
Apr 21, 2009 | Computers & Internet
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Sep 07, 2008 | Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Print spoole
has this been resolved?
Jan 10, 2008 | Dell A920 InkJet Printer
PRiNt SP00lER
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
http://www.usa.canon.com/consumer/controller?act=DownloadDetailAct&fcategoryid=357&modelid=10238 Above is the Canon site with the newest drivers available. Download them and install them. First "delete" the printer from print properties. Unplug the printer from the wall for a few minutes and shutdown the computer. Plug the printer in and reboot the machine. Install the new drivers. You are in a loop. definition of LOOP: see LOOP. Let me know what happens. Good Luck, Tim
Feb 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
414 people viewed this question
jasbo
jasbo
