Question about Gateway Profile 5.5 PC Desktop
SOURCE: I installed a new hard drive in a Gateway 4XL.
Sounds like the HD will need a low level format from a boot disk or a boot CD.
If it hasn't been done then the BIOS won't see it and Windows CD won't either.
If you have another system available, you can set it as a Slave or Cable Select, plug it in and format it from that system if the OS can see it at all.
Some HD's used to come with that disk. Most don't need it now.
Of course...it may be a dead drive too..........
Tony
Posted on Mar 07, 2009
SOURCE: I have a gateway Profile 5. when i cut it on
My understanding is that when you power on your PC, the POST is succesful, but then the system hangs.? If i am correct. There are several reasons this may happen.
1) Boot record corrupt
S) Reformat the harddrive and re-install operating system / replace hard drive
2) General Hard drive failure but boot record instact
S) Replace Hard drive
3) Operating system inoperative
S) Re-install operating system
Most pre-built systems come with recovery disks, you may try this as a solution if available.
When replacing a defective hard drive, or partialy inoperable hard drive, a good policy is to change the drive to slave, and install the new drive as master, this way any data you may be able to recover, can be done after the new hard drive is installed, and an operating system is installed on the new drive.
(POST = Power On Self Test)
Posted on May 29, 2009
SOURCE: gateway Profile 4 with two hard drive failures
How do you know 2 hard drives have failed, have the hard drives been fin in another computer.
most likely the OS is corrupt on the disks caused my another hardware issue, most likey Motherboard IDE/sata controller.
Posted on Sep 07, 2009
SOURCE: gateway gm5442 very slow to boot, 20 to 30 minutes.
You said you tried different CPU, but it was the same motherboard, right? Maybe the motherboard speed (data bus, etc.) is just slow. Otherwise, there's not much left to try if the hard drive works OK in another computer and you've tried upgrading the memory, CPU, and power supply.
Posted on May 29, 2010
Testimonial: "yes that seems to be the only solution left. have not came accross one that acted as this one does, but i guess it was a learning experience for me. Thanks for all the input."
Aug 12, 2011 | Gateway ZX493131e Notebook
Mar 13, 2011 | Gateway Profile 4 All In One (MPN...
Nov 12, 2017 | Gateway MX6428 Notebook
Jul 16, 2010 | Gateway Computers & Internet
Jan 02, 2010 | Gateway Profile 4 XLb PC Desktop
Sep 06, 2009 | Gateway Profile 4 All In One (MPN...
May 12, 2009 | Gateway Profile 5 PC Desktop
Apr 06, 2009 | Gateway 310S (2900621) PC Desktop
Mar 01, 2008 | Gateway Solo2300 200MMX Pentium, 200 MHz...
Feb 09, 2008 | Gateway M305CRV Notebook
82 people viewed this question
send me a picture of your CPU's front where the cd drive and power button is, and the inside of it. I will help you
codeteal@live.com
