Question about NetGear DG834G Router
I lost the password i created to my Home Network and now i want to put 2 laptops on my network. Can you help?
    New Friend:
  • 76 Answers
We do not help Hack passwords here.
Posted on Mar 04, 2015
Pterocarpous
  • 202 Answers
SOURCE: office network
Hi Gishmou,
You don't need the older (wired-only) router any longer. You can use the newer router for your entire LAN - just as you did w/ the older one.
"Wireless" routers are capable of both wireless AND wired connectivity. "Wired" routers, however, can only manage "wired" connectivity.
Perhaps this is where the confusion lies? Please, let me know if I am misunderstanding the issue you are experiencing.
If I understand your issues correctly, the 1st thing you'll need to do is take the older router out of the picture.
(01) Disconnect all connections from the old router and remove it from your network.
(02) Remove power from the new router and the cable modem.
(03) Connect the WAN port of the new router directly to the cable modem.
(04) Connect the new router (via an Ethernet patch cable) from one of the LAN ports of the new router to the computer you would like to use for setting up the router.
(05) Restore power to the cable modem and wait for approximately 1 to 2 minutes (or until you get a solid (always on) Internet or WAN led lit).
(06) Once you're sure the cable modem has established connectivity w/ your ISP (Internet service provider), then restore power to the new router.
(07) Give it a minute or so - it will need time to p/u the cable modem connection.
(08) Now, from the computer you have directly connected to the router via a patch cable, enter the router setup utility by opening a browser and entering the router's LAN IP address or by using the setup CD that came w/ the router.
IF the reason you were attempting to keep the older router along w/ the newer router was you needed more than the (usually) 4 or 5 LAN ports available on your new router?
If that is the case, install a network HUB or SWITCH and connect it (usually w/ a Cross-Over cable) to one of the LAN ports on your router. (If you choose to do this, we'll help you set it up and wire it properly.)
The older router you are using is quite possibly not capable of being set up as an "Access Point" (rather than a router). There needs to be one router then you can use an access point or a hub or a switch to increase the number of nodes on the network that will be supported.
If you'd like assistance finding the documentation and setup instructions for this router, please, let me know.
Please, post back here w/ any questions at all you might have and w/ the results of the steps you've taken. We'll continue to work w/ you until your network is up and running properly. @:)
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
Posted on Apr 09, 2008
redhaze89
  • 854 Answers
SOURCE: secure network
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
3. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 11, 2009
  • 85 Answers
SOURCE: I have set up a secured wireless network in my
Hi
With Netgear you can export the settings and read them in notepad. The Key you used will be located in there.
You can always take it to a reputable computer shop and ask them to find it our for you if you struggle with the export.
Taz
Posted on Oct 30, 2009
Basti
  • 1447 Answers
SOURCE: forgotten password to connect to network
In order to check or change your password for NetGear , go to http://192.168.1.1. It will ask you for a user name and password. The default is “admin” and “password”, Once you are connected, go to Wireless Settings and you have the option to change password there.
Hope this helps
Posted on Apr 28, 2010
arvinds88
  • 108 Answers
SOURCE: My Dell Inspiron 700m Laptop
The model of your laptop which you have specified carries with it a wireless receiver: Intel PRO/Wireless 2200 (802.11 b/g) Internal Wireless adapter. Other devices may be 802.11n compatible. So check the wireless mode in the router. Also make sure that the network name is also being broadcasted by the router. Finally check for any wireless devices like cordless phones, microwave ovens, etc.
Hope that this will help you resolve your query in the best way they can... Thanks 4 asking,
Arvind S Iyer
Posted on Sep 24, 2010
What is my network password
Only you or the administrator of the network will know that. It is stored in the router and must be entered to access the network. We cannot help you on that one. However, in the worst-case scenario, if you cannot remember the password, you can, if you know your router password, go into the wireless setup and create a new password. Remember then that all devices that connect to the network will need to have their passwords changed to remain connected. If you do not have the router password, then you may need to reset the router to factory defaults. This is done with the reset button that is recessed into the device, usually on the bottom or rear. Once that is done, you can use the factory default login information to re-configure the router to the network and create a new wireless password.
Feb 02, 2016 | HP Pavilion Computers & Internet
How do I fix my hp625 problem which ask for the password of its homegropuser$
Try this it comes from the windows help file on Windows 7
You should let Windows manage
your home network connections because it's the easiest and best way to share
files and printers.
But if you've previously set up customized sharing permissions on
your network following the procedures in Windows XP or Windows Vista and you want to maintain those
permissions when using a homegroup, you can choose to manage network connections
yourself. If you choose this option, you'll need to use your user account and
password when accessing other computers.
To continue using customized permissions, create or join a
homegroup, and then follow these steps:
  1. Click to open Advanced sharing settings.
  2. Click the chevron to expand the
    Home or Work network profile.
  3. Under HomeGroup connections, click Use user accounts and passwords to connect to other computers,
    and then click Save changes.
Oct 26, 2013 | Computers & Internet
WILL NOT CONNECT TO LINSYS HOME ROUTER BUT WILL CONNECT TO WORK NETWORK
What do you mean it won't allow you to put in the home network passcode? When you click connect to your home network, does the password request come up for you to put it in? If not, you've got your settings wrong on the laptop
There are some configurations that allow you to put in the password and then are are some that allow you to use a pin. I bet you've got your connection in the laptop configured wrong.
Apr 28, 2012 | Dell Latitude E4310 Laptop
Forgot my password in my new laptop how to find
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
or
Ebay you can purchase a
Password Unlock/Recovery For Windows 2000/XP/Vista/7
Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7
Buy It Now price: US $1.49 (Approximately AU $1.50)
also
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
hope it helps.
don
Feb 25, 2011 | Acer Computers & Internet
Connecting to my existing network at home.
What type of wireless station do you have? Have you tried to connect the wireless station with another computer? Feel free to visit digitalsupporttech for getting help.
Aug 25, 2009 | ASUS Eee PC 701 Notebook
Vista Laptop cannot connect to XP users
go to control panel>>add and remove prgrams>>click on add/reomve windows components on the left panel.
make sure you have the system CD.
put a check mark in "networking services" and "other network files and print services" install the addtional services.
check the share volume, make sure you have given the user rights to access the drive.
Jan 30, 2009 | Microsoft Windows Vista Ultimate Edition
I need to put a password on my wireless router so neighbors cannot access my internet connection.
Access the configuration page of the router by typing in 192.168.0.1 on the address bar.
>Type in Admin/admin on your the log-in page and leave the password blank click ok.
>If you created a username and passsword used that one, if you forget your username and password reset the router for 15 seconds. Reset button is located at the back of your router and use admin on the login page.
>Once inside, click on HOME and on the left side choose WIRELESS
>Enables should be choosen.
>Under SSID, change your network name to a new one.
>Under Network Authentication choose WPA-PSK
>Key type would be passphrase
>Type in your password for your network. mimimum 8 character.
>Click on Apply >Continue.
>On your laptop, connect first to your wireless network before accessing the Internet.
Jan 21, 2009 | D-Link DI 514 Wireless Router (DI-514)
Have wireless network at home trying to add my sons laptop to network but have forgot security key/passphrase which laptop is asking for
All you need to do is log into the router usually with the pc that is attached to the router (wired) by typing into the run command box http://192.168.1.1 Depending on the brand of router you'll either put in admin and no password or admin for the password or admin and password for password. Once in the router go to the wireless security tab and you can see the network key. Hope this helps
Nov 06, 2008 | Computers & Internet
Wireless Network for my laptop
You must purchase a wireless router. I recommend Linksys. If your laptop has ethernet capabilities this will work just fine. (ethernet ports look like oversized phone cord ports) they are very simple to use and install in minutes. just be sure to make sure your network is password locked!
If this helps, I would really appreciate a FixYa! rating. If not, do not hesitate to contact me. I own a linksys wireless router, and can help you install it, if need be. Have a good day!
Apr 30, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Belkin WirelessG Plus Mimo
I'm pretty certain that you can only have 1 host per computer/per name for a network. So, if you want to change the laptop as host you will have to setup a network under the settings. Create a network password along with the network name for that laptop. (Unidentified Network) is a correct network name. It's just that you probably didn't change it to a specific name that you wanted it to be in the box. after doing this, you should be able to go to the other computer's and try to log onto the network domain that you have created. after that in order to get approval to access the network domain you have to enter the encryption key which is the network password. you have to do this to all non hosted computers. after completion, you should be connected to that specific network.
Now you want you're desktop to be the host. Well, from above do the same steps for the desktop. But, instead of (in example) to lets say your laptops network name is (Home). Well, you would have to make the host name on the desktop to be (Home2). then set the encrption key. Then go to all non hosted computers including the laptop that you made the first network. because this is a new hosted network created by you're desktop and connect to that network and then supplying the encrption key to be able to access the network. and you should be good. Just my 2cents. although this may not work because you may have to have to routers to be able to create multiple networks but, like you mentioned earlier you have a wireless on you other laptop you can use the setup for that wireless to make another network. Hope this helps and good luck ;)
Dec 02, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
NetGear DG834G Router Logo
237 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
