Question about Garden
I have a 3yo cub cadet zrt50 mower with a Kawasaki FH661V engine. I ran a tank of gas through it last week mowing with no problem. This week I filled it up after running out of gas and it will not start. I have gas coming out of tank, through filter and pump into carb. Spark plugs are dry. sprayed carb. with carb cleaner and engine will start on the cleaner but will not keep running...any common problems or suggestions?
  • 2 more comments
  • libbys2 May 24, 2011
    Thanks...I will try your solutions....but my time to work on it will be limited for a few days.
  • libbys2 May 27, 2011
    I weekend mechanic....so I haven't been able to get to all of this answer...but it makes sense the problem is carburetor related and may need a good cleaning. Thank you for the quick response.
    Good quick solution...I will try it before tearing into the carb. Thanks
  • Joshua hawkee
    Joshua hawkee Jun 05, 2014
    turn key to start position ,you should hear a click if not could be fuel solenoid
    Genius:
  • 1,015 Answers
I would go ahead and put a new fuel filter in it.Remove float bowl and make sure no small particles are hanging float up. Check the vent hole on gas cap and clean if needed. Check clean or replace air filter. I also would drain fuel through system while float cover is off and dispose of it.I would close neddle vales all the way and note position and number of turns to close. Then remove neddle valves and let a small amount of gas run through them. Put valves back in and try to get back as close to where they were.I would also run more carb cleaner thru it and hopefully get and dirt or rust particles cleaned out. Thank you.
Posted on May 24, 2011
  • 710 Answers
Hi libbys2,
I think the fact that you ran out of gas is your problem. There's probably sediment from the tank plugging the jet in the carburetor. If you don't want to take the carb apart, try putting more of the carb cleaner in and running it to flush it out. If that doesn't work, you might have to rebuild the carb.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 25, 2011
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Mower w/ kawasaki FR651V engine, cranks, runs 10 minutes, cuts off. Tried plugs, fuel pump & coils. whats next?
kawasaki are dirt and water sensitive chang full filter and clean carb out remove old gas from tank and clean good then refill with super unleaded gas should fun good then
Sep 20, 2014 | Cub Cadet Garden
Cub cadet with 24 hp kohler v twin that acts like it is flooding out after 20-30 min of mowing.stop mower and it picks back up,may mow 2 feet and start doing it again,seems to do it mainly when turning or...
It sounds to me that you have something in your gas tank that is intermittently plugging your gas feed hole. Inspect in your tank for something floating around in there and pull it out.
Apr 13, 2014 | Cub Cadet Garden
Kawasaki lawn mower engine
You probably may have valve seals leaking, or an internally vented carb which is now flooding and sending fuel into the oil, this needs addressing straight away as it will cause damage to the engine as it thins out the oil.
Aug 25, 2013 | Garden
I have a cub cadet LT1018 with 800 hrs. The engine, B&S 18.5 hp, started running rough and sputtering while mowing. Disengaged PTO to return to garage - mower died. Cleaned air filter and restarted,...
Sounds like water in your carberator. Remove the bowl and check for dirt and water, drain some gas from the tank into a bowl and check for water in the gas. Remove air filter housing and lubrcate all of the carberator linking with a product such as WD-40. Reassemble everything and start again. While you are at it check the spark plug too.
Oct 20, 2017 | Cub Cadet Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
296 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
