Question about Dell Latitude D600 Notebook
Just bought a new 120G HD for my Dell Latitude D600. The following error message comes up every time I turn it on: MEMORY ADDRESS LINE FAILURE AT 28000000 READ 00000000 EXPECTING FFFFFFFF DECREASING AVAILABLE MEMORY STRIKE THE F1 KEY TO CONTINUE, F2 TO RUN SETUP UTILITY. So I hit F1 and it works fine. Is decreasing available memory going to cause a problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
While the "memory loss" won't cause a major problem, you will be annoyed by the repeated message. A couple of things may be causing this. One, Windows changed the virtual memory size. This is an area on your hard drive that the computer uses to store stuff when the on board ram isn't large enough to handel it. the other thing that may be happening is you have a memory module going bad. You must remember that the hard drive size has nothing to do with the memory size. That is, your ram memory is what handles most of the processing of information. Your hard drive is just a storage place. Like a file cabinet in your office.
If this information was helpful, please rate it high. Thanks
Posted on May 24, 2011
Testimonial: "thanks laptopwill, Trying to get my daughter through college. Saving on a used laptop makes it possible. :)"
Cant set up
You need to insert the CD/DVD that came with your computer and boot from that.
Apr 24, 2013 | Dell Latitude D600 Notebook
I amtrying to install windows xp pro onto my dell computer but keep getting this message memorywrite/read failure at 03002fd8,read 00af00ef expecting 00ef00ef decreasing available memory what do i do
You have a one bit memory failure (bit 23) in your RAM memory just above the 50 Mb area, (address 50343896)
You will need to replace the failing memory module.
Feb 19, 2010 | Dell Latitude C610 Notebook
Have a Dell Latitude D600 will not boot. All LED
LEDs indicate a memory error
Reseat RAM and try modules one at a time. If ony 1 module, replace it
Dec 16, 2009 | Dell Latitude D600 Notebook
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
Dell d600 displays disk error read
check your bios settings and see if the drives are configured right. the c drive must be drive 0. the other thing comes to mind here is the hd has become corrupted or a bad read head in the drive. try running setup defaults. if this dosent work it might be time to restore it, or replace the harddrive.
Jul 13, 2009 | Dell Latitude D600 Notebook
Dell "Drivers and Utilities" CD
NEEED TO GO INTO CMOS SET EVERYTHING UP DATE THE HARD DRIVE , CD ROM, DVD, FLOPPIES DRIVES,HD DISK, HDS, CYCLDR, SETORS,
C-MOS BATTERY MAY NEED TO BE REPLACED,
ROD
DRIVERS
WWW.DELL.COM/DRIVERS
WWW.MOTHERBOARDS.ORG
WWW.MRDRIVERS.COM
WWW.DRIVERSHQ.COM
WWW.TOMSHARDWARE.COM
WWW.WINDRIVERS.COM
ROD
GO ON LINE AND TYPE THE FOLLOWING;
DELL LATITUDE D600 DRIVERS
OR
DELL INSPIRON 1150 DRIVERS
ENTER
ROD
Feb 10, 2009 | Computers & Internet
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Thanks for your initial efforts , ref dell latitude d600 laptop.
Well there is certainly a RAM related problem. You have to open your RAM Module, Clean its golden coloured edges and reinsert it properly. Then start your laptop to see if it changes anything. If everything remains same then you have to replace your RAM.
Be very carefull if you open your RAM. Consult your Manual first.
Nov 24, 2008 | Dell Latitude D600 Notebook
Dell latitude d600
try to reseat memory on computer,take it out and put it back in again..
Sep 30, 2008 | Dell Latitude D600 Notebook
Dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
Aug 23, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
166 people viewed this question
Alun Cox
