We have a error code 469 on our polar 66 guillotine does any one know what it means the blade is slowy raising !!!
  • 1214 Answers
SOURCE: The crank to raise and lower the blade on my
The square tooth screw and nut tend to fill with sawdust, which saturates with oil to cause the threads to bind (like a dirty nut and bolt.).
Clean the bolt with a cleaner, then apply a little wax to the threads (crayon or bees wax). Be sure to run the assembly up and down to cover the whole "bolt" and make sure to apply to the point of the screw that assures some of the wax works into the nut.
Wax is less likely to cause wood dust "mud" that WD-40 or other lubricants would cause.
Check the slides or guides that guide the assembly as well. CLean and lubricate with wax as needed.
Let me know what you find out.
Posted on Dec 12, 2009
SOURCE: Kenmore Classic Grille model 911-469-8813 error F2
Over time I have had to replace the control module at the front of the oven. It gets baked by the oven heat, and unfortunately costs hundreds of dollars to replace. I have avoided further failures by making sure the downdraft exhaust fan is ALWAYS on when the oven is on. This seems to keep it cool enough.
Posted on Feb 17, 2010
erdnasetab
SOURCE: hello we have a polar guillotine
Hi.
Its caused by the clutch disc binding on the shaft. Usually a strip down and clean up sorts the fault.
07808 901184
Andre Bates
Independent Polar guillotine engineeer
Posted on Feb 20, 2013
erdnasetab
SOURCE: safety bolt locked on polar guillotine
I can fix that.
07808 901184
Andre Bates
Polar guillotine engineer
oliphantlapt
SOURCE: I have cleaned the worm
Lubricating most likely is not enough based on your description. You need to adjust the alignment of the blade raising worm gears. This is covered in the manual on page 12.
Here is an exerpt:
Blade Raising Mechanism
Adjustment
If binding occurs, clean off all sawdust and pitch
buildup and re-lubricate with a good non-
hardening grease. If binding continues, check
the fit-up of the worm and worm gear segment.
The worm must be centered with the worm gear
segment. If it is not centered, loosen the saw raising arm set screws, move the arm as
required, and re-lock the set screws. See Figure
22.
Posted on Apr 20, 2014
Polar 115 EM ,1987 guillotine
Compressed Board? Probably dulling the blade, so after a few cuts, it starts to drag the stock. Try a fresh blade or moving the material to the other side of the cutter.. If you watch the gauges and pressures all look good, I can think of no other problem. I'm not a tech, just a long time user. If any air might be getting in, you would most likely see fluid spraying out.
Nov 15, 2013 | Kitchen Appliances - Others
Can I replace the blade on my paper guillotine?
On a paper cutter with blades that slide on a track you are able to replace the blades but not on a guillotine, it appears the only solution is to buy a new one.
Sep 29, 2013 | Office Equipment & Supplies
Eror code 66 how to fix it
you might want to unplug the set and plug it back, my list does not show a code or error code 66 for this set. Power it up and let it fail and check for the error, if the wrong model was posted here that may be the reason.
Dec 23, 2012 | Mitsubishi WD60735
Safety bolt locked on polar guillotine
Bolt locks are pretty cheap and don't usually cost more than $10. You can get a new one.
Nov 14, 2012 | Cars & Trucks
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
Jul 14, 2012 | Water Heaters
Machine says "I need service"
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
I have cleaned the worm and Gear segment for blade raising mechanism on my 66 and it still binds and is stiff. What do I do next?
Try lubricating with silicone spray. I use it for just such things, and I'm happy with how it works. Also, clean and lubricate the lock on the elevation control.
--W/D--
Jan 29, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Nov 18, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
213 people viewed this question
jasbo
jasbo
