Fog lights not working when switch is turn on
  • 3,530 Answers
Welcome to Fixya
First thing that you need to check there is the Fog lights fuse. Go to your fuse box and look your fog lights fuse. Replace the fuse whether its busted or not.
Please let me know if you need futher assistance.
Thank you for using Fixya!
Posted on May 24, 2011
High beam indicator comes on with fog lights
Could your Mazda have daytime running lights? If you checked all fuses, did that include the three in the joint box?
There is an auto light-off control module that is central to all functions you describe. It is assumed that you would only turn on the fog lights with headlights on and set for high beam. If you set the headlight switch to LOW, the module closes the headlight relay to turn on the low beams. If you then turn the headlight switch to HIGH, the module turns on the high beams and allows you to turn on the FOG LIGHT switch, closing the fog light relay and turning on the fog lights. Since this sequence is not working, I suggest checking both high beam lamps as both could be burned out. Other possibilities are a defective headlight switch or the module
Oct 01, 2012 | 2005 Mazda 6
To activate fog lamps 2006 altma do you need to change headlamp turn switch
Yes, the 2006 has the fog light switch on the headlight switch which is also the turn signal switch, another way is to install a fog light switch, this will not be as the factory setup which works off the headlight switch but will save some money.
Jan 21, 2012 | 2006 Nissan Altima
Signal lights dont work and want to know where the fog light switch is at
With the switch in sidelight or dip
position, pull the switch to its first
position to turn on the front fog lights.
Pushing the switch in or turning it to OFF
or AUTO will turn off the front fog lights (this is for the front)
With the switch in any position except
OFF or AUTO, pull the switch to its
second position to turn on the rear fog
lights. This will also turn on the front fog
lights unless main beam is selected.
or AUTO will turn off the rear fog lights (this is for the rear)
Exterior lighting
Exterior lighting switch
A. OFF.
B. Side (parking) lights.
C. Headlights.
D. Auto.
E. Front fog lights.
F. Rear fog lights.
It is the round knob nest to the steering colume
Aug 18, 2011 | 2003 Jaguar X-Type
My headlights on bright and fog light is not working. I have changed the bulbs and they still don't work. The fuses seem to look okay. What else should I look for? Do they have another fuse or circut fuse...
Most fog lights turn off when you put your brights on. Check their operation in normal mode first, if they turn off when you turn your brights on... this is normal.
To disable this you need the wiring diagram for your car, you will have to cut 1 wire to be able to have all your lights on at the same time.
Nov 04, 2009 | 2000 Pontiac Grand Prix
2001 1/2 Passat... fog lights & Cruise Control
to turn on the fog lights, its the same switch that you use to turn on your head lights. Turn the dial to the right to turn on your head lights and then pull it towards you. thats how you turn your fog lights on
Jul 04, 2009 | 2001 Volkswagen Passat
Fog lights not turning on
Sounds good to me except, the switch light shout be on the relay primary circiut and light off until you turn it on. When you turn the switch on, it lights up and energizes the relay, the relay closes and completes the secondary circiut for ythe fog lights. VIOLA' I have a silverado. done deal thanks
May 28, 2009 | 2003 GMC Sierra
1st time install of OEM fog lights into a 1999 Mercury Cougar?
Look under the dash near where the headlamp switch mounts and if yours is equipped you should see I think it is a blue 4 pin connector with the following wire colors OG,OG/WH,OG/GN,BK.
This is for the fog lamp relay.If yours has this connector then you will need to purchase a relay ford part number F6RZ-14N089-AA should list for about $10.
Feb 25, 2009 | 2000 Mercury Cougar
Dodge dakota selector switch and relay switch
A selector switch is what you use to turn on or off a circuit such as the lights or wipers. A relay switch is used by a circuit that has a large current draw and a relay uses a small source of current to control a large usage of current. Most fog lights use a relay to control the fog lights. You turn the fog light switch on (that is a selector switch) and the current from that circuit then activates a relay switch to let the larger current draw that the fog lights use go to the fog lights and you have light. A relay also controls if the fog lights are on when the bright lights are on. (on most cars if you turn the bright headlights on the fog lights will go out until you go back to the regular lights)
Hope that helps.
Good Luck
Jan 08, 2009 | 2001 Dodge Dakota
Can't turn on the fog lights
hi from uk if you are meaning rear fog light/s ? they will be on the switch that has a picture of lamp with horizontal lines ? these will only work with headlight on also if you are meaning front drive/fogs then the same goes for these ie a similar switch near to lights switch or you may have to turn on h/lights then pull outwards the actual switch as on uk cars? the idea being if weather conditions req fogs then h/lights must be on also preventing driving on fogs only and no obligatory side/tail and h/lights here in uk hope this assists you locating switch ? wish you merry xmas
Dec 23, 2008 | 2001 Hyundai Elantra
Lights
Your fog lights should not work with high beam... they should work with the low beams. they are connected wrong, which probably drew too much current through the light switch burning out the contact points for the parking lights in the switch
Start by Fixing the fog light connections to work with low beams. Appears to me this was not factory installed. Aftermarket kit maybe! Then see if your parking lights work. If parking lights don't work still and everything else works, replace the light switch $50 at the dealer. The switch works the fog lamps when you pull out the knob to turn on the fog lamps when the lights are turned on. When the fogs are on you will see a little amber light to let you know your fogs are on. When you switch to high beam the fog lamps go off. Again if its not working that way, then is wired wrong. Needless to say, there should be connectors in the harness of the lights for the fog lamps. Use those if possible with the kit that you can get at the dealer, or you can splice the connector with those blue splicing clips sold at the auto part store. Make sure ground is ground when splicing and water proof the connection sith silicone and tape.
Dec 13, 2008 | 2004 Ford F150
Computers & Internet Logo
David Payne
David Payne
