Question about Bionaire BT40RC Fan
I have bionaire bt40rc model tower fan ,it sqeels on all 3 speeds i have tried oiling with sray oil. Need to get apart to properly oil bearing. were to go to get break down manuel to take apart
2 Suggested Answers
  • 300 Answers
SOURCE: My Bionaire Tower fan is
I don't think it is a defect, but you may want ot check with the store.
I have a similar one that starts at a higher speed and switches down to low after a few seconds.
After that I can select the running speed.
Posted on Apr 01, 2011
My fan motor is not working totaly
PROBLEM; My fan motor is not working totally!
So, i guess that your fan motor is working partially
because it is not working totally.
Please try to be more vague, if you posibably can be.
You will loose 10 points if you actually give any one an idea of what could be wrong with your fan.---ha-ha! sorry,it just seemed too funny to me.
Sounds like:----option #1------- your fan motor is either not running at proscribed speed (fer instance, high is not high enough or low is too low.) This is usually caused by lack of oil on the fan motor bearings.,easy to oil the bearings & dirt cheap too.
but could be caused by an almost burnt out fan motor.In that casethe Motor is not fixable, & needs 2 -B replaced, but dont bother to. It is cheaper to buy another fan at wal marts.
option #2
that portions of the 2 speed or 3 speed selector switch are not totally making contact.
or --option # 3, one of your motor windings could be burnt open.
So,let me start with --#3-- the worst case senarieo
Diagnostic proceedure for Dr. Fixit
You need to supply 120 volts ac in turn to winding lead #1, then to winding lead #2 and then to winding lead #3----
There are 4 wires on a 3 position fan speed switch.
1 wire for low speed,1 wire for medium speed and 1 wire for high speed. This looks like the letter Y with each leg of the Y
[ around the outside of the Y ] being one speed winding. THe neutral return wire would hook up to the center of the Y and this would give you your 3 circuits, depending on which outside leg
that the speed selector switch selects. lo,med or hi--- the neutral return wire at the center of the Y will compleate the circuit, one winding at a time ,depending on speed selector switch setting, for all 3 speeds.
All 3 speed windings need to work for the fan motor to work totally.
If one speed winding is burnt open, the fan motor will only work partially, 2/3rds ,that is. You can still use the fan by cutting off the lead of the bad speed winding and using the other 2 windings.
If 2 wings are bad and dont run, the fan will still work partially with only 1 speed.
If you have no-- or intermittant contact on your fan speed switch,
you will have to order a new replacement switch. This is assume-ing that all 3 speed windings worked properly at their respective speeds , when you tested them earlier , with the speed selector removed from the circuit for testing of the motor windings to see if they each work with the selector switch out of the circuit
If you know that all 3 speed windings run ok , with the selector switch cut out of the circuit, then you know that the speed selector switch is bad.
Firstly,unplug the fan from the electricity so that your hair does not stand up on end, which would surely be a shocking experience.
secondly,
remove the old speed selector switch, noting down on paper, what color wires go where and put the same color wires from the new switch back in the same place that that color wire of the old switch came off of.
(i know this sounds funny, but it really totally works.)
use electrical tape and/ or wire nuts to make electrical connections, if necessary.
With the new switch installed, the 2 or 3 fan motor speed settings will now totally all work.
most electric fans have steel rotor shafts with bronze bearings.
they "call" them oilite bearings,susposedly because the bronze bushing (it is really a bronze bushing) but called a bearing, is oil impregnanted and susposed to be good for the life of the fan.
that is only true if you expect the life of the fan to be ONLY 18 to 24 months which is the average time that the factory oil lasts.
the oil dries up the longer the fan runs and the shaft makes the bronze bushing begin to heat up due to increased friction and eventually wear the round bronze bushinhg egg shaped.
Try giving your bearings a good healthy squirt of sae 30 wieght oil from a zoom spout-- [pull out straw squeeze bottle refillable oiler.]
I recommend oiling both the front and real fan motor bearings once a month.
This is the most common cause of fan failure.
Because I oil my fans bearings once a month,I still have fans that run from 1940,1950,1960 and 1970. The 1940 GE fan lasted 70 years and is still running strong.
Some newer fans have chinese ball bearings , but the ball bearings also die prematurely from lack of needed oil.
Sometimes, you can pry off the bearing race cover to get oil into the bearing.
a good trick here is to use wd40 if you think you cant get sae 30 into the bearing.
wd40 is a n extreemly light wieght oil that penetrates very well
and gets into places where you think it wont get into .
You can totally wet up a fan motor with either
sae 30 or wd 40 or both without worrying about the electric
motor being harmed by the oil.
the oil,sae 30 or wd 40 wont hurt the motor.
On badly rusted and nearly siezed fan motor bushings , or any electric motor as well, I use first wd40 for penetration and then sae 30 for good long duty lubricatin.
You may have to keep squirting ioil in the motor for 1/2 hour and end up with a puddle of oil under the fan motor, but about 40 % of the time ,you can bring back to life what yo thought was a dead motor. Perserverance is required and faith that you can fix the motor. 40 % of the time you get sucess to one degree or another and 60 % of the time ,its kaput for good.
I got all those fans i mentioned before because other people thought the bearing were seized and shot, and put the fans in the garbage pail where I rescued the fans from.
the bearings were almost siezed but far from shot becaue i got oil in to the shafts and bearings and another 12 to 20 years of life from the fans. However,i do oil them monthly in fan season, which is winter time for me, since I use fans to blow the hot air off of my wood stove.
Oct 10, 2013 | Dryers
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
Do I clean model FS10-S4R the same as model FZ10-9HB have had this for a long time really needs cleaning bad it is a wonderful fan
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 27, 2012 | Tower Aloha Breeze Fan
Motor stopped working. I need aloha breeze phone number
Aloha Breeze fans are manufactured by Litex. You can contact them at:
3401 West Trinity Blvd.
Grand Prairie, TX 75050
Phone: 800-527-1292
Jul 20, 2011 | Tower Aloha Breeze Fan
Bionaire bt16 towerr fan not working. Only slight beep noise when turned on. Two years old.
Possible that the capacitor is weak and so does not power the coils to turn rotor. you will need to check the free movement of the blades, is no use some oil to free the rotor blades, if the blades are free then check the continuity of the coils specially if they are heating up , if so check the capacitor.
Jul 05, 2011 | Bionaire BT40 Tower Fan
My Bionaire Tower fan is Switching the sitting by itself from 1 speed to 2 speed. is it a defect?
Mar 31, 2011 | Bionaire Tower Fan w/ Ionizer and Remote ...
Bionaire bch9221-um tower heater is still creating hot air but I think the fan is not blowing because it is not making that whirr sound that it usually makes and the hot air smells like it is burning on...
Hello christillejo,
A total CLEANING works wonders...!!
Check the fan for VOLTAGE... If present & ...
If it is not running... shut it all down... and clean your fan parts with at least 70% alcohol... blow it dry and set it aside while you find your HIGH-GRADE (CLOCK-TYPE) silicone oil...
Put a wee bit (oil) on your freshly cleaned bearing surfaces.
While the FAN might not run a complete 15 to 20 years it did before... this procedure can add years to your FAN'S life-cycle.
In the meantime... check your OPTIONS for an opportunity
appliancepartspros
Search Over 2 1 Million Appliance Parts
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Partsselect
PartSelect Appliance Parts and Repair Help
Carnac the Magnificent
Mar 21, 2017 | Bionaire Ceramic Tower Indoor Space Heater
Fan making humming noise and wont turn
The fan motor cannot turn because either the bearings are dry and turning hard or the motor has worn out...You can try to take it apart and lub the bearing with WD-40 and a light oil... it may work.
heatman101
Apr 19, 2010 | Tower Aloha Breeze Fan
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Bionaire BT40RC Fan Logo
95 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
