Question about Brother EM-530 Typewriter
Directions arent clear enough in manual to change correction tape
  • Brother Master
  • 3,594 Answers
Install the full spool on the L. side thread the tape around the guide rolls with the dull side towards the paper, put take up spool on R. spindle, wind up slack.
It may be easier if you remove the ribbon and print wheel first.
DickyO
Posted on May 27, 2011
I dont know why my phone somtimes hang am using n81 8gb
i have N81 8gb so i put everything on the mass memory directly.(even the msgs). i recieve "memory full" and "carousel/telephone/ sysAp- not enough memory 2 perform" i cant access the camera, clock, cant change the profile or change the time and date.the phone memory has 25MB it says they r used but actually they arent, i tried 2 install an manager application but it doesnt accept since the memory is full while actually it has nothing in use just empty folders which cant b deleted.clearing the cashe memory didnt work nor *#7780#. i even tried the *#7370# but it did not work either. i dont mind losiing everything on the phone or mass memory. i tried updating and reinstalling the software
led store
May 06, 2012 | Health & Beauty
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
Changing correction tape
Go to brother.com, click on support you will find a manual there.
DickyO
Jun 25, 2010 | Brother EM-530 Typewriter
Typewriter won't erase letters completely.
Correction tapes do have a shelf life and can dry out. You should try replacing the correction tape and see if it is better. If that does not fix it, does the tape lift up high enough to cover the entire letter? If not, you have a lifting problem and will need a tech to fix it.
May 28, 2010 | IBM Wheelwriter 6 Typewriter
Need to know what size and hoe to change belt for yardman 46" cutting deck for blade model # 13a0771h055
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Cant get radio into aux mode so i can play mp3 player directions in manual arent clear on how to get radio in auxilary mode
Hello luvbetty4eve,
Without knowing exactly what make and model of receiver you have, it's not possible to provide specific instructions. But for most receivers, both stock and aftermarket, there is a "source" button sometimes shown as "SRC". To change from one source to the next, you simply press the button repeatedly until the display shows the one you want, in this case usually "AUX".
Jun 25, 2009 | Kenwood Car Audio & Video
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
I NEED OWNERS MANUAL TO KENMORE DRYER
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Mar 27, 2008 | Kenmore 63942 Dryer
Brother EM-530 Typewriter Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
