Question about Whirlpool Dishwashers
Whirlpool dishwasher Model DU1345XTVQO, Serial NO: FY2206044, TYPE 575-0. Problem: dishwasher does not empty water from unit during the wash cycles; activating the CANCEL/DRAIN function does not empty the water either. Problem seems to have started a few months ago with some water left in the bottom but activating the DRAIN function would discharge it. Now that doesn't solve that problem.
  • ratkey Jun 10, 2011
    Macmarkus,
    First i would like to say thanks for the quick response to my request for help with the Whirlpool dishwasher and the very clear directions for dis-assembly and troubleshooting. Even noting what size of star sockets to use saved me a couple rtips to the barn for the right tool.
    After following your instructions and removing the filter and chopper screen, all looked brand new. Trying the dianogistics test indicated that all systems worked but the water still remaining in the bottom (approximately 1.5 gallons) required 11 manual pumpouts.
    So I uninstalled the unit and checked the drain hose behind the dishwasher and at the drainpipe beneath the kitchen sink. The sink end had some green goo in it and the dishwasher end looked kinked where it lay beneath the unit. I replaced the hose with a new 5/8 inch heater hose and all now works fine.
    BTW all this took the better part of a week because I have too many projects going on but there is no FIXYA solution to that.
    Again thanks for the assistance.
    Craig Ratkey
  • Whirlpool Master
  • 2,605 Answers
Hello, Welcome to FixYa.
Based on your post I understand you have a drainage problem with a Whirlpool dishwasher. t
ypically with these machines having poor washing and incomplete draining it can be chalked up to obstructions in the sump assembly. Here's how to inspect it and clean it if necessary.
Try this link if you think you're not too confident. They aren't pros, but it is a good guide for accessing the sump assembly relatively easy. This combined with my tutorial you should be fine.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to Whirlpool dishwasher Model DU1345XTVQO, Serial - 87fb0d6.jpg rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove Whirlpool dishwasher Model DU1345XTVQO, Serial - macmarkus_416.jpg
i.e.
Now you should see the chopper and screen asseWhirlpool dishwasher Model DU1345XTVQO, Serial - macmarkus_615.jpgbe clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
NOTE: Pay particular attention to the area where I've placed the arrow. It is a back flow check valve and can get debris stuck in it allowing water to back flow into the sump after the drain cycle ends, hence you get water left behind.
The other thing to inspect is the drain. The proper drain should actually be tied up at least as hi as the top of the dishwasher and the closer to the machine the better, but if it drains into a sink or disposer right next to the machine as long as it is tied up under the sink it should be fine...you also want to rule out any kinks in the hose of course.
Now you'll need to run a "reset" test sequence to observe it's performance. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the pump itself is at fault...we'll cross that bridge if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 24, 2011
Whirlpool dishwasher DU1015XTXBO Stopped working during cycle, acts like don't getting any power. Checked the plugin and it works. No lights or anything coming on the dishwasher. Its like it just
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
Feb 17, 2018 | Whirlpool Dishwashers
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
Bosch SHE44C07UC/22 - FD8606 : pump does not run during wash cycle, but does run during empty cycle. timer works. fill works. empty works. relays are heard about 2 minutes into fill cycle. may be...
Hi 2ipnelson,
Very difficult to know for sure which part is not working.
It is best to run the dishwasher in testing / service mode to ascertain which component is not working.
I found a .pdf document that explains the whole process, it should also work for your SHE model.
The link: LINK - CLICK HERE
Follow the steps, and the culprit part should be diagnosed.
Hope this helps :-)
* If this solution helped you, please accept it
Jul 26, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
My whirlpool dishwasher is not getting any water to it. it goes thru the cycles,but no water.it is about 6yrs old..model#GU1200XTKQO serial#FL3716278 type 575-0
sounds like a bad water valve you can disconnect wires ohms it out with a meter and see if its good or not . your looking for continuity. go to searspartsdirect .ocm to see price for part and they will ship
Mar 03, 2010 | Whirlpool Dishwashers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
It takes water. heats,and will empty but do not wash
can you hear the motor/pump running during the wash cycle. pump or spray arms maybe clogged with debri.
Jan 05, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Extremely long cycle
The drying coil that is broken also heats the water during the wash and rinsing phase. Right now it is waiting for the water to heat up, that's why it's pausing. Replace broken heater, they are relatively cheap and can be gotten at repair clinic.com.
Feb 16, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
222 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
