Question about D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205)
What switch chip is in the DGS-2205? - D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205)
D-Link DGS-2205 Can I use this device (switcher) to connect two or three computer to internet? At the moment I just can connect only one computer using this switcher. My service provider is Comcast and...
You sure can connect 4 wired computers via the DGS2205, you need to make sure u have a wired modem/router connecting to the switch to have internet
ROUTER > MODEM > SWITCH > COMPUTERS
Jul 03, 2017 | D-Link DGS-2205 5-Port Gigabit Ethernet...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Is it worth the extra price for a Netgear switch
For general home networking, you will not see a difference in performance if all you are doing is sharing internet connections / printers.
If you are wanting to share very large files between PCs, then you might consider purchasing a more expensive one.
D-Link makes surprisingly good equipment for the price.
Mar 16, 2010 | D-Link DGS-2205 5-Port Gigabit Ethernet...
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Port speed issues with my DGS-2205
Gigabit swich does not enough for a Gigabit network, you also need to get your computers to support it, that means Gigabit network cards, buy if you don't have and you really need to, they are quite cheap these days.
If the above is not the case than it is barely possible, but worths a check, if you are using simple CAT5 cable instead of CAT5E or CAT6 (cable type is written on the cable, see for yourself)cable for the network?
If this is true consider doing a rewireing if really nessesary for speed, but cat5 is ok for gigabit around 10 meters distance for very good speeds.
However to do a little speedtest on your own first is not a bad idea at all, try to copy some big files between 2 computers and check the speed, 100Mbit networks used to do speeds about 8-10 Mbytes/sec that should do it for most networks, gigabit networks can do more, my record in my home network was 50-60Mbytes/sec, but mostly it's around 30Mbytes/sec.
Remember, better cable can do better speed and sometimes length affects network speed if the cable is very long (above 50 meters). And prepare, that you are not really going to reach the theoretical maximum speed of 125Mbytes/sec with common PC hardware. Maybe with some RAID based system or SSD can help you out, but most people don't really need that kind of speed.
Oct 17, 2008 | D-Link DGS-2205 5-Port Gigabit Ethernet...
Dgs-2208
What are you trying to do?
Aloha
Bob
Apr 23, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
DGS-3024 Gigabit-Ethernet Switch
Open a web browser an put the IP address of your switch in the addresse bar. Once in the web interface, open the Monitoring folder and then click the Port Utilization link. The switch is actually creating graphics of each port utilization.
Much more details are provided in the user manual:
http://support.dlink.com/products/view.asp?productid=DGS%2D3024
Click on the "Product Manual" link at the left.
Mar 17, 2008 | D-Link Switch 24-Port 10/100MBPS
D-Link DGS-2205 5-Port Gigabit Ethernet Switch (DGS2205) Logo
56 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
