Question about Rosen CV7081D Car DVD Player
I have a Rosen Z8 installed in my new car and have only just tried using it. It says "disc error" for every DVD that we've tried. Does it mean it's faulty? I have tried emailing Rosen Entertainment but they have not replied.
4 Suggested Answers
  • 3 Answers
SOURCE: cant find headphone socket for rosen in-car dvd player
As far as i know, all Rosen in-car dvd players come with IR (infra-red) headphones so the sound is transmitted that way rather than using a lead from the headphones to the unit, therfore no sockets are neccessary!
Hope this helps....
Posted on Apr 09, 2009
SOURCE: parking brake by pass for my VW Jetta
on your main screen, change your source to "A/V In".. you should get a black screen. Touch the upper right corner of the touch screen and it'll pull up a number menu. Type in "7253" then hit OK. from there, there's a choice that says "brake" hit the right arrow till it says off. Then you're off and runnin SON!
Posted on Aug 25, 2009
  • 5370 Answers
SOURCE: My rosen Car DVD player
In most of the cases, this problem is not related to cd.But still get the cd checked in any other player too, this will confirm the fault. Also try other various cds in the cd player and confirm. But if the cds not playing in other player too then its faulty cd.But this is very rare. Most probably the fault is related to cd player. In the cd player unit there are two main parts. One is cd spinning motor and other is cd reading lens(its also called "EYE" of the cd player).But if you hear that cd is spinning but its not playing,. This clears that motor is working, but its not playing so its the problem of lens.But if you dont hear any cd spinning noise then both motor and lens problem are there, and any of the one is possible. The lens is not reading the cd,because its got dirty or its got cracked and faulty. The cd player lens is made up of thin glass and its very delicate. Many a times dust gets collected on the lens, so the lens stops reading the cd and it do not play. Some times there is no dirt on lens but it gets cracked, if by mistake any pressure is applied on the unit or up-side down cd is placed in the tray or internal short circuit has occurred. These are few possibilities of lens not working. But in most cases its dirty lens causing this problem. SO open the tray by pressing the eject button, then turn of car, by keeping the cd tray open. Then take air blower and blow air in the unit. Please remove, if there is any cd in the tray while blowing air. Just blow air for few minutes. Then take a dry tissue and clean the cd placing tray externally and then turn the power on to car and see, if that is helping or not. If the problem is same as before, then disassemble the unit and clean the lens manually by hand using dry tissue paper and then see if its helping. But take care while cleaning the lens with dry tissue , and you doesn't apply too much pressure on lens or any other parts. Also before removing any screw to disassemble the unit. Take a marker with you ready. Just mark the position of parts and screws before removing. If you have a cell phone with web cam in it then take a photo of the internal parts before moving any parts. Disassembly is not very hard but reassembling is not easy. So this pictures and marks with help you for reassembly. ----------But if lens is cracked internally then the lens assembly has to be replaced. You can get it replaced from local cd /dvd player repair center. They have these parts with them. --------------- To take apart cd player, you need to remove it out from dash .Check both the things, the cd lens and wiring to the motor, which spins the cd inside the player.This should help. Thanks. Helpmech.
Posted on Aug 11, 2011
HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Nov 28, 2012 | Computers & Internet
How to wire domelight in rosen overhead dvd player
put dvd purple wire to the car gray wire your traverse has positive trigger. Hope that works , switch has to go to positive on dome switch . Please post back if that works.
Jun 27, 2012 | Rosen G10 Car DVD Player
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
The last week the DVD player isn't working. In some cases, it will spin the DVD (and I've tried multiple DVDs to be sure) and then display the error message "bad disc". Other times, it...
Hi kjones1021,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the optical lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc, this is because of the movement of the optical lens back-and-forth. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the spindle motor - Check the spindle motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 09, 2011 | Philips PD9012/37 DVD Player
Can my moto z8 open word files? if yes how
Your phone is running Symbian OS, so I'm pretty sure it can! As far as I know, there are full office software packages available for that os, but I've never used Symbian myself. My advice to you is to visit these two sites (google them): ModMyMobile and MobileModding.US, there are subforums dedicated to the Z8 on both, you will find the answer to this and any other Z8 related question there!
Sep 05, 2011 | Motorola Mobility MOTORIZR Z8 Cellular...
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
Aug 28, 2011 | Acer Computers & Internet
Rosen g10 disk error and dvd will not play
something is jamed inside dvd player or its dirty need disc cleaner.
Feb 17, 2011 | Rosen G10 Car DVD Player
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Rosen CV7081D Car DVD Player Logo
85 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
bigdawg7299
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
