The / * - + . keys on right side of keyboard are not working. The number keys are working - but the math functions are not
  • 749 Answers
You can solve it if you have a basic knowledge in Electronics... Open the keyboard and simply trace and test via tester, the circuit of the keys that are not working and should be able to patch it to make the connection.
If not knowledgeable in electronics... well, you should buy a new one instead.
Good luck.
Posted on May 24, 2011
Key working alpha
The alpha key activates the alphabet keyboard and a few extra symbols. To access the MATH menu and the ToFrac command, press the key below the ALPHA key. The key is marked with MATH.
On the TI84PLUS with the newer operating systems (version2.5x), the APLHA key opens up a few functionalities. That is not available on the TI 83Plus.
Sep 02, 2013 | Texas Instruments TI-83 Plus Calculator
Left side of keyboard 123456789 is not working
Do you mean the right side of the keyboard is typing numbers instead of letters?
If so, you have enabled the NumLk which turns the RHS of the keyboard into the number pad.
Press the NumLk key near F11, F12 function key and the NumLk LED will switch off and return your RH keys back to letters.
Jun 15, 2012 | Toshiba Satellite L500 Series Notebook
What are the names of kyboard and its keys ?
it is only for a computer keyboard hope it help from you.
A computer keyboard serves as a main operating tool for accessing and inputting data into a computer. The keyboard features many functions and keys that a user may never use, but is still essential to some users. Understanding the keyboard can improve computer knowledge and use.
QWERTY Pad
The "QWERTY" pad is main sections of letters on the keyboard. These letters are mainly used for typing and also as shortcuts in programs like Windows Movie Maker, Adobe After Effects and computer games.
Number Pads
The far right side of the keyboard features a number pad that resembles a calculator. This number pad is essential for programs like Excel, but can also be used to input numbers as a typing function. More numbers are just above the "QWERTY" keyboard that also feature symbols when the "Shift" button is used.
Arrow Keys
The right bottom of a keyboard features four directional arrow keys. These keys provide navigation through word processing documents and also serve as scrolling functions in web browsers.
F Bar
The top of a keyboard features the "F Keys," a selection of keys that extends to "F12" on most keyboards. These keys serve different functions. For example, "Alt and F4" exits out of a program. "F1" will start the typing helper in word processing programs.
Extra Keys
New keyboard feature shortcut keys at the top of the keyboard. These include shortcuts like "Power," "Sleep Mode," "Calculator," "My Computer" and "Web." Some also include media controls for movies and music.
Aug 11, 2011 | Acer NSK8458AN Keyboard
Iwant to be ablleto balance check book usig the right side calculator pad
try the combination of
Fn Key and NumLock Key (both Fn and NumLock will be of a diff colour on the Key board) and you will have the numeric key pad available
and the same function again after your work will unlock the nummeric key pad also
hope could be of help
Mar 28, 2011 | Dell 0Y3740 Keyboard
I have a new HP keyboard which seems to have three or four choices for upper and lower case. For instance, the number 6 key has a choice of 6 or ? or several other designs likw an arrowhead which I cannot...
Keyboards can have various functions for each key that are enabled by first pressing a modifier key. Some keyboards may have an Fn key that stands for 'Function' that are identified by a bluish-purple color.
You would have to hold down the Fn key before being able to use the corresponding function.
Other keys may have items that can only be used once you press the NmLk (Number Lock) key. Usually you only have to press the NmLk key once to enable these alternate functions and then press it again to disable.
Mar 12, 2011 | Computers & Internet
Cannot use right side numbers of the keyboard, other functions ar
I'm not sure what keyboard you have but there should be an "Fn mode", "Mode" or similar button on your keyboard, it should be the same color as the function icons on your other keys. This is usually used to toggle between the different modes. If this doesn't work or only works while your holding it down then you'll need to find the setting software for your keyboard. It's most likely in with your other programs or in Control Panel, some will put an icon in your task tray that you can double click or right click to access them.
May 02, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Function key needs reset - For any key with an alternate value normally reached by holding the Fn key to obtain...I must depress the Fn key to get the ''normal'' key value (I am doing that to type this)....
Your numlock button is on. Somewhere on the keyboard you will see a key labeled, NumLK or something similar, press this. It is usually located somewhere in the upper right side of the keyboard. What this allows you to do is turn on the number keys that are also associated with these keys, just like a normal keyboard has the number keypad on the right side, this key turns on the functionality, gets a lot of people.
Dec 31, 2009 | Dell Vostro 1510 Laptop
Ibm think pad
The IBM laptop has a key on the top row on the right side.It has two functions. One function is the scroll lock on the bottom of the key.The other function is the numbers lock which is at the top of the key.To unlock the right side of the keyboard when numbers are coming up instead of letters, hold down the shift key and the numbers lock key and that will unlock it.
Sep 28, 2008 | IBM ThinkPad T42 Notebook
Numbers locked
If the function key isn't releasing the numbers lock, then the keyboard has malfunctioned and will need to be replaced. You can get a good deal on a replacement keyboard on Ebay.
Jul 02, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
