Ethernet controller properties the drivers for this device are not installed. (Code 28) just reformatted my PC. can't get online due to this prob.
  • 31 Answers
Te solution to this problem is to reinstall the drivers for your network card, depending on the operating system that you are using.
This code means the device was not installed completely.
To resolve this issue, follow the recommended solution. If that does not work, try removing the device from Device Manager and using the Add New Hardware wizard to redetect it. You may need to obtain updated drivers if the error still occurs.Check if you dont have the drivers and utility disc, if not you will have to use another machine to log on the internet and search for the drivers, If your machine has got enough resources to run windows 7 (as in the ram above 1gb, Processor preferably duo core and enough starage space) windows7 will detect all drivers for your machine.
Regards
Egroeg
Posted on May 24, 2011
Because I can not connec to internet via the ethernet cable (code 28)?
Go to the Control Panel>Device Manager>Network and find the adapter installed in your unit. Right-Click on the device, go to Properties and note if the drivers are installed...if not, install them
Jul 21, 2012 | Sony VAIO VPCEE31FX Notebook
I have problem for multimedia audio controller not installed in my pc asking for code 28 pls. help me thanks
Code 28 is:
The drivers for this device are not installed. If you are asked for the driver and you do not have it, you can try todownload the latest driver from the hardware vendor's Web site...
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
Please let me know if this was helpful and if itsolved the problem and good luck..
Sep 10, 2011 | Computers & Internet
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Driver won't download intellinet ethernet driver os 98
Try to manualy specify the path to your driver using driver update.
Oct 06, 2009 | Microsoft Windows XP Professional
Code 28
Code 28 The drivers for this device are not installed. (Code 28)Recommended resolution
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
Mar 27, 2009 | Microsoft Windows XP Professional
5315
Code 28
Install the driver
Code 39
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Cause
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Thanks
Mar 06, 2009 | Acer Aspire 5315 Notebook
Ethernet controller driver code 28
i need ethernet controller software for compaq(model NO: sr5060il)
Sep 27, 2008 | Gateway 310S (2900621) PC Desktop
Code 28 drivers
how do i fix code 28 for free
Apr 14, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
