Question about Royal Sovereign Bill Counter with Ultraviolet Counterfeit Detector (RBC 1100)
The counter says EA3 and i do not have the manuel and the buttons wont work? this is a new machine and hasnt been used much, do u know how to reset this to make it work??
Why is it displaying error message EA3 and won't work?
EA3
Joined notes. Put the notes from the stacker onto the hopper again, press RESTART to count again.
http://www.royalsovereign.com/media/downloads/54/RBC-1003BK_OM.pdf
Jan 09, 2016 | Royal Sovereign Bill Counter with...
Reset drum minolta di 2510
Has the drum been replaced? IF not then recommend that the counter not be reset because the copier use the counters to determine voltages for certain assy. like drum and developer unit, so if you reset the counters with out replacing the parts the machine will give codes and provide bad copy quality issues. Reset code is the only way the machine knows it got new parts
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 29, 2012 | Minolta Di2510 All-In-One Laser Printer
I have a bizhub 350 and the machine wont let me into svc mode and wont tkae the admin pass. How do i clear the nvram to the machine and how and where do i get the software to do so. Please help
Service Mode : Hit the utility button/Counter List/Stop-00-Stop-0-1/Then it will ask for a number, key in eight zeros and hit enter or print button.
In order to perform a nv-ram clear, there is software you can put on a SD card and startup the engine holding down the utillity button.
May 25, 2010 | Office Equipment & Supplies
I left the transit bolts in our "brand new" zanussi washing machine and am afraid to use it as I do not know what damage might have been done.
Highly unlikely any damage will have been done so long as it hasnt been in use for a long time (weeks).
In a front loading washing machine, most of the mechanicals inside are held between springs at the top and dampers at the bottom. The transit bolts are used to minimse how much movement can ocour whilst the machine is in transit as excessive movement could damage the springs/dampers. When they are removed, normal movement of the mechanicals helps keep the machine stable and minmises vibration.
So, the worst that happens when the machine is used with the transit bolts in place is it vibrates alot, and possible moves about.
Remove the bolts as soon as possible and it should be fine.
Oct 04, 2009 | Zanussi ZWF12070 Front Load Washer
Error message EA3
Bump this have same problem
Apr 27, 2009 | Office Equipment & Supplies
Toshiba dp80f-Drum unit warning
menu, 5, 2, 0, 4, 1, enter
This will reset the counter for the drum unit.
Feb 12, 2009 | Toshiba DP80F Printer
Lamp error
keep an owner manuel, can download one online, but you need to replace the bulb, then reset the counter. to reset the counter press (-) volume on the tv then while holing that down press the pip button on the remote that will reset the counter
Jul 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Royal Sovereign Bill Counter with Ultraviolet Counterfeit Detector (RBC 1100) Logo
518 people viewed this question
Top Royal Sovereign Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Royal Sovereign Office Equipment and Supply Expert? Answer questions, earn points and help others
