Question about Creative Labs Video Blaster WebCam
I DONT HAVE DRIVERS FOR USB ADATA S 805 FOR WINDOWS XP
Divers A-DATA C906 windows 7
Looks like ADATA only supports windows XP. However, Windows 7 should recognize it natively.
http://www.adata.com/index.php?action=ss_main&page=ss_content_driver&lan=en
May 10, 2014 | ADATA C906 16 & 32GB USB 2.0 Drive
Driver for adata c008/8gb xp sp3
Try looking here:
Mar 24, 2014 | ADATA Classic Series C008 Retractable 8GB...
Driver for adata superior sh93 500 gb external for windows 8
you dont need a driver.
i cant find SH93?
the top complaint it the USB cable is no good.
or falls off, or likes to get half/inserted and fail.
try a new USB cable.
see if windoz (is it on a mac?) disc managment can see it.
see if windoz) lick USB task bar icon can see it. (1st)
when you plug it, in to USB port (yes, try them all, and other systems.) the USB port goes dingdong, (connect sound)
does it?,
if , not it for sure did not connect. fix that first.
Sep 29, 2013 | ADATA Superior Sh93 500 Gb External Hard...
New Adata usb flash drive 8gb wont work
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
May 03, 2012 | Electronics - Others
EasyPeasy installation using USB
dont bother with linux nothing works on it and it messes up lots stay using windows
Jul 21, 2009 | Acer Aspire One AOA110-1588 Notebook
Usb Driver For Huawei SmartAx Mt882 for win XP professional
Windows XP Professional doesnt require USB Drivers, these Driver built in Windows XP professional
or there already present in ur system..........
so go ahead connect anything to ur usb port(like digital camera, mouse, pen dirve, flash driver , memory card reader,..portable harddisk , digital cameras)
when u insert any of the component(for eg: pen drive) in to the usb port OS will automatically detected these devices and install USB Drivers.... dont worry... about this  and be rest assured....OS will do the work for u...............
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
USB 2.0 (Chipset VIA 8237) ECS P4M800-M7 Unknow Device
Hi, John
The USB 1.1 and USB 2.0 is a big issue regarding technology, the 1.1 has maximum speed of 12 megabits where as 2.0 has upto 480 Mbps. And all USB 2.0 devices are compatible with 1.1. Windows XP Home Edition and Windows XP Professional are both fully USB 2.0-compliant with the correct drivers.
So in your case it must work properly. But if the USB 2.0 from microsoft got currepted or badly updated by some thirdparty USB 2.0 driver then it will not work. I have been faced this problem. After doing some stuff I found that if I uninstall the USB drivers and reinstall it from microsoft driver then it works.
So, just go to the Device manager and un-install the USB drivers, then reboot the system to parmanently delete the removed driver. Then install the driver from Windows XP CD.
good luck
Thanks
Iqbal
Mar 25, 2008 | EliteGroup P4M800-M7 Motherboard
Creative Labs Video Blaster WebCam Logo
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
