Question about Marantz Arch 1.0 Shelf System
I have a MARANTZ ARCH and it has just started to develop problems with the cd draw it opens and closes fast a few times then will open and close normal also the flap will fold down draw will come out the when i want to close it the flap will go up first before the draw has gone in and stops the draw it takes some gentle persation, my query is can this be fixed simply or is it a sign of worse things to come as i have been researching this problem with other owners and the next step is always failure of the lazer, whats your opinion? thanks
    Problem Solver:
  • 16 Answers
If the system is less than 3 years you still qualify for manufacture warranty, usually it is accumulated dust, you can open the system's case and clean with a dust cleaner can, you can buy at staples, best buy, radioshack, and any major store.
If dust is not the problem than is an electronic problem, there is one electronic component that is in charge of closing the flap at xx speed. If that one is burnt out you can replace it, I recommend you have an electrician look at the circuit. or Contact the Marantz for warranty at: http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx
Posted on May 24, 2011
How to open a stuck CD drawer
After removing the mech look for a pulley wheel underneath and turn it with your finger
May 22, 2014 | Marantz PMD325 CD Player
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
Hi, My young daughter held the tray on my new cd5001 player as it was opening. The tray now opens and closes continually while the unit is turned on. It will not play discs and the words open & close...
while your daughter was "holding" the tray did you hear any "popping" type noise?
This is a typical sympton when the gears have skipped a few teeth!
Your best bet(IF your a "handy" person) would be to take the unit apart to get to the CD drive, and CAREFULLY push/pull on the tray to manually "open/close" it, and watch the tray in correlation to the "eye" mechanism, to see if it is aligning with the "hole" in the tray correctly!
Jan 22, 2011 | Marantz CD5001 CD Player
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
Cd does not read every time
I love Marantz! They make quality products that last and sound excellent! Most likely it a dirty lens. When a lens gets dirty, it can't read the cd as accurate. Unplug it, remove the cover, locate the cd lens take a q-tip lightly dipped in rubbing alcohol and rub it lightly on the lens (don't drip it too wet). This should help. Sometimes they also have a weak laser which can cause the same problems, but try the cleaning first.
Apr 23, 2008 | Audio Players & Recorders
Cannot print onto CDs
Firstly - check that the CD draw at the front is fully closed. Sounds daft, but many have been left ajar and caused the fault. If the draw is fully closed and you have opened and cl;osed it a couple of times, then there is a problem with the switch that is use to detect the draw opening. Check that the contact point on the printer body is intact as per image1. It is possible it may have been broken off. The other possibilities include the switch (located within the draw itself) is faulty, broken or not conected. In this situation you would need a service manual to disassemble the draw and test the switch/cables. If all else is ok, it may suggest a faulty main board in the machine. Look for a manual at http://www.TheServiceManualShop.com if you intend to dimantle the machine
Jan 26, 2007 | Epson Stylus Photo R200 InkJet Printer
226 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
