Question about Cisco 7942G IP Phone
I need to know how locked and unlocked keyboard of cisco ip phone 7942G
SOURCE: Cisco 7912G IP Phone
You can not shut off CCM CSRST fall Back service. You need to either remove SRST reference in the device pool or for the phone specific configuration. I suggest you create device pool similar to one you have but without SRSR reference. Then you need to re-apply device pool in the phoone configuration and restart the phone.
Posted on Jun 09, 2008
ward_knutson
  • 64 Answers
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
  • 5 Answers
SOURCE: Cisco 7970 ip phone, can't pickup call
Make sure you have both phones in the same call pickup group. I have never used the group pickup button. The regular pickup button is what I use.
Just to be clear the procedure is..once phone A rings you hit the pickup button on any other phone that is in the same group as phone A. After you hit the pickup button the call will be drawn to the phone that you hit the pickup button on. Once the call is on that set hit the answer button to answer the call.
Posted on Aug 01, 2009
  • 121 Answers
SOURCE: CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Posted on Feb 19, 2010
SOURCE: CONFIGURE ip pHONE 7912G
My phone cuts in and out. I am hooked up to a Rogers Rocket Hub with a static ip address.
Posted on Jul 12, 2010
Cisco 7942 factory reset
When performing the factory reset procedure we are about to describe, it is important to keep in mind that the IP phone will lose all configuration files and phone applications. This means that it is necessary to have CallManager or CallManager Express setup so that the IP phone will be able to receive the new information (phone application and configuration) after the reset procedure is complete, otherwise it is most likely that the IP phone will not be usable until this information is loaded on to it.
This preparation also happens to be the procedure for upgrading a Cisco IP phone firmware.
Follow the steps below to successfully factory reset your Cisco 7942, 7962 IP phone:
  1. Unplug the power cable from the phone and then plug it back in. The phone begins its power up cycle.
  2. While the phone is powering up, and before the Speaker button flashes on and off, press and hold #. Continue to hold # until each line button flashes on and off in sequence in amber.
  3. Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Oct 10, 2014 | Cisco 7942G IP Phone
Is there another way to put it on dnd??
yes, ask system admin for *code to dial
Sep 02, 2014 | Cisco 7942G IP Phone
Cisco 7942G IP phone works in home office but it does not work in remote location
Hi J,
Typically corporate use VPN for these kind of critical service access. Check with your IP Tele/Network admin and get VPN access or may be OfficeExtend or any other solution employed. Corporate don't expose their UC servers on internet w/o security.
HTH
-Karthik.
Oct 14, 2012 | Cisco 7942G IP Phone
I cannot register phone in remote location
Duplicate question. See other post for clarification.
The very first password that comes with the phone new out of the box. I can't access the voice mail without a password.
The voicemail password is typically set on your PBX or Callmanager. The phone is only a registered extension, when you enter the VM password it is simply passing those digits to your PBX for validation.
Sell Cisco Phone Equipment
Aug 31, 2012 | Cisco 7942G IP Phone
Not working cisco 7962
For starters, have you obtained a Cisco Phone power supply for your 7962G? These phones require either a local 48V AC Adapter, or Power Over Ethernet, in order to power up.
Mar 04, 2011 | Cisco 7942G IP Phone
Want to delete messages
Login to your vm box and listen to your messages. Press 3 or 7 to delete them.
Dec 20, 2010 | Cisco 7942G IP Phone
How can I unlock a SPA922 that has ben Locked? I can´t do factory resett becouse it is locked!
1.On the Cisco IP Phone, press the Settings button.
2.Press **#
3.When the window displays Settings Unlocked, click the More softkey.
4.You now see the Erase softkey, which can be used in order to erase the configuration on the Cisco IP Phone.
I hope that this has been very helpful for you
Dec 18, 2009 | Linksys SPA922-EU IP Phone
Method 1:
1) Unplug the phone
is a second method.
Method 2
  1. Press Settings.
Also see this link
May 18, 2008 | Cisco 7910 IP Phone
Cisco 7942G IP Phone Logo
80 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
