Question about Blenders
I need the ( plastic male tip ) that fits over the metal rod end opposite the blade end of a wolf gang puck 550 watt emersible blender. the part fits into the plastic female receiver end of the detachable mechanical portion of the appliance at the separation point
  • tspressly May 25, 2011
    thanks for the hsn #, however, because it was a gift, i did not have a hsn acct.# to reference the order to. she was kind enough to give me the wolf gang puck #1-800-275-8273 or online www.wppotsandpans.com. the situation has been resolved and i appreciate your initial step in starting the process for resolution. hopefully this information may help you in the future.
    yes
  • 1,998 Answers
Says to call this number for warranty information so I would assume you should be able to get the parts from this number as well or they could provide you with a number to obtain parts
  • For warranty information, please call HSN.com Customer Service at 800.933.2887 (8 am-1 am ET).
IF this number is uneffective after you call message me back and I will look further into where you can locate your part Thanks Rick
Posted on May 24, 2011
  • Rick Ead
    Rick Ead May 25, 2011
    Gratz glad this helped Thanks again for using fixya
    Rick
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
Blender does not spin inside the plastic bowl. The blender works, but does not spin the blades inside the bowl.
mine just broke as well the hand blener is working but the piece on top of the inside lide broke off so as not to make a good attachment with handle where can i geta lid
May 02, 2010 | Wolfgang Puck Immersion Blender
A blade on my immersion blender was bent slightly. The motor still works and the blades spin, but they no longer emulsify. Can I buy just a new blade attachment?
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Jan 16, 2010 | Wolfgang Puck Immersion Blender
Wolfgang puck bistro blender won't turn on, need
I had the same problem. There's a little button on top of the base that is supposed to get pushed in by a male-type piece on the bottom of the pitcher. I broke a match stick and duck taped it so that it pushed in the button on the base - Voila! it works!
Jul 06, 2009 | Blenders
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Braun Blender MR500HC
We'll Match Any Authorized Dealers Price. Your Appliance Authority. www.AJMadison.com Or you may visit : Braun web site
Jan 08, 2008 | Braun MR 550 M MultiQuick Handheld Blender
Blenders Logo
1,167 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
