Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
I have a Maytag gas range(MGR 4452 BDS); the oven temp cannot be set above 350 on the electronic/touch control panel. The surface burners work and the oven will heat to 350, but no higher. Is this a defective control panel, a defective oven sensor probe or something else?
3 Suggested Answers
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Posted on May 18, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: Maytag Gas Range With Touch Control Model: CRG9800C,
Sorry to read about your problem, I hope this helps you out.
You could have 3 different problems.
1. defective gas control valve to the oven
2. defective temp probe
3. defective gas control knob
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
If my electricity goes out is there anther way to light my gas stve that has and electronic ignighter
If you have a gas range that allows the gas to flow freely on the surface burners, you can light them by using a match or lighter. Hold the match or lighter adjacent to the burner you intend to light and slowly turn the gas on. The burner should light.
However, the oven still will NOT work due to that fact that modern ovens are electronically controlled by the control panel on the range. So...you will still be able to cook, using the surface burners, but the oven will not function. If you have any questions, please post back and let me know. I hope this helps you.
Feb 03, 2011 | Kitchen Ranges
Maytag Gas Range With Touch Control Model: CRG9800C, CRG9700C, CRG7700B, CHG9800B When the oven temperature is set at 350 degrees it will not go above 75 degrees. Gas Burners work
3 Thumbs - Helpful
Dec 31, 2010 | Maytag Kitchen Ranges
Electronic panel malfunction
A F1 code on Jenn Air refers to a failure in the ERC (electronic range control). There is not a fix for it other than replace the control.
It looks like the part is still around if your model starts with JGR8850 that is. The price of the part is around $300.00 so.... not sure if it would be worth putting that into this, your call
May 08, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
57 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
