Question about Vizio E320VP 32" LCD TV
We lose the speakers when I plug in the earphones. Plugged the ear phones into a single jack because the red white cable did not work.
    President:
  • 2,761 Answers
Plugging into the HEADPHONE jack will always mute the speakers - that is a normal function. If you use the red and white AUDIO OUT jacks you will need to connect them to an audio amp.
Posted on May 24, 2011
How do you connect headphones to a emerson flat screen tv
should be a red and white right next to the yellow try them
Nov 02, 2012 | Televison & Video
Speaker is off
Most of these combo units do not have a speaker ON or OFF setting but look anyway.
If the set has a earphone jack that may be the problem--see if works with earphone plugged in.
The socket the jack goes into can get flaky as when jack is inserted it turns the sound OFF.
Also put your ear right to the speaker to see if anything at all is heard--the speaker could be bad--but check the above first.
SD TECH
May 27, 2012 | JVC TV-13142 13 in. TV/VCR Combo
Hi, the headphone jack is not working at all! I have a Latitude D610. I've had the laptop from my company. Do you know how to address this problem? thank you very much
Does the main speakers work on the laptop? as you know when the headphones are plugged in, the internal speakers turn off. If the laptop speakers are fine then you have a problem with the ear phone jack, it needs to be replaced, or part of the original has broken free of the motherboard and needs to be resold-ed. If on the other hand you have no sound at all, the ear phone jack has comletely broken free or the audio ic is the problem. Regardless of the issues the laptop needs to be dis-assembled to address the problem.
Jan 07, 2011 | Dell Latitude D610 Notebook
I have turned the tv on and in the top right hand corner there is a symbol for earphones and i cant get the normal sound back on
yoiu likely have a sound output selection in you setup menu .. or in some sets they sense the fact that ear phones are plugged in (switch in the ear phone jack) .. and that automatically shuts off the main speakers .. sometimes the ear phone jack gets damaged and the set thinks there is always an earphone plugged in .. if thats the case then the jack would have to be replaced or repaired ... or you could for the time being, run a cable from the ear phone jack to an external amplified speaker (like a computer speaker .. that would get your sound back at least until repairs can be made ..
Nov 27, 2009 | Cell Phones
How to connect my wireless headphone to a Panasonic LCD TV, there is only a single earphone jack mine has got 2 plugs
That's a new one, 2 plugs would indicate seperate audio ( right and left ) or 4 . Try this go to RadioShack and buy a Y that you can plug both plugs into and then plug the single plug into the TV jack. Look at the plugs on the headphone sender do the plugs have a single band or double? If single use above solution, if double just plug 1 plug in.Good Luck.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
The sound comes and goes from right part of headset
The left/right problem could be a bad connection on the red/white XBOX cables. Check to see that they're plugged in properly and not loose. You can also try plugging an MP3 player into the red/white jacks to see if the problem is with the headset or the XBOX. If it works ok with your MP3 player, then the headset is working fine.
You can get a new headset controller cable on our web site. Click on Replacement Parts in the left menu for the headset model you own (X1, X3, or X4).
Jul 04, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
No ear speaker?
sometimes the phone thinks there are earphones plugged in try plugging earphones in then unplugging again also try volume up and down and it will display earphone on screen keep plugging in and out until it does not say earphone on volume
if that doesnt work restart phone
Jan 16, 2009 | Apple iPhone 3G
No sound from ear phones of Fujitsu S-series laptop
First ensure that the headphones are working, by testing them on a divverent devices.
Ensure that computer has sound from speakers, if computer has not sound at all , then you need to reinstall audio drivers.
Then restart the computer with earphone plugged in, this solves a bios control related problem.
If still no luck, than you may have a broken solder joint on the Jack socket, in that case the repair must be done by a technician.
Jan 07, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
External Sound Card
No, that's not going to work. Digital output is just that....Digital. Your trying to send a digital into analog....won't work. Your tv don't have red and white audio out. That's what you hook to, but it still wouldn't be 5.1. Your out of luck my friend. The ONLY way you'll get 5.1 out of that T.V. is to get a 5.1 reciever with CO-AX digital input...the SAME as whats on your T.V. You can only hook-up sound to your X-FI with the line in jack using a y-connector and 1/8" stereo plug....and it won't ever be 5.1. It can't that way. Only way to get 5.1 to work on the blaster is with the tosh-link optical input cable. This too is digital, but uses optics to send it. Remember, you are playing with 2 different formats. Analog with your white/red thing you made and then digital. Digital using co-ax or optical tosh-link. Completely different.....as you now know.
Oct 23, 2008 | Dynex DX-LCD37 TV
Pioneer sx-315 receiver stays in phones in mode and no sound is coming out of my main speakers
Simply stick the tip of a screwdriver in the input and it will reset. (:
Feb 24, 2008 | Pioneer SX-315
Vizio E320VP 32" LCD TV Logo
212 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
