Question about Multitech Systems MultiModem ZBA (MT9234ZBA-USB) Analog Modem
New modems (3 of them) type MT9234ZBA-USB did not power on. Cables are ok, we tested them on other usb equipments.
How can you connect a USB modem to the HP touchPad?
Ok 1st you will need an adapter so you can connect through the mini/micro USB port on the Touchpad, you can get that here on eBay, follow the link.
http://www.ebay.com/itm/New-micro-USB-USB-Female-Cable-USB-OTG-N900-/150678760608?_trksid=p4340.m185&_trkparms=algo%3DSIC.NPJS%26its%3DI%26itu%3DUA%26otn%3D5%26pmod%3D110726781644%26ps%3D63%26clkid%3D3595217049355083996
You will need a Modem that is self powered, that is to say plugs into house power, the mini/micro USB port on the Touchpad is not powered. Contact any computer supply store for a Modem like this.
Oct 19, 2011 | HP Compaq 236076-001 Touchpad
Tip
Tutorial to connect lg phone to a P C
<b>This tutorial works for most of d lg cellphones which don't provide a dedicated application to make our task easy.... <br /></b>Generally frm LG mobile official website (<a href="http://www.lgmobile.com">http://www.lgmobile.com</a> <span>[nofollow]</span>), we don't get pc-suite like nokia to make our tasks easy, dey just provide USB modem driver for recognising ur mobile....<br />Requirement,<br />A LG cellphone, a usb cable, usb modem driver frm LG website.........<br /><br />Steps-<br />1-connect ur mobile & ur OS will ask u to install driver for nw hardware found<br />2-Locate d downloaded driver and install it as prompted....<br />3-Go to device manager (type devmgmt.msc in run box frm start menu)<br />4- Look for ur new device installed under com & ports section & note com port no...<br />5- go to control panel - phone & modem option- add - select- "don't detect my modem" - next- under standard modem types - select standard 33600bps modem- next- select d com port u noticed in step -4 - next/ok<br /><br />Now check if everything is ok by selecting now installed modem - properties- diagnostics - query modem........<br /><br />Now follow d procedure mentioned in d above post by admin to set up gprs connection........
on Jan 29, 2011 | Cell Phones
How can you connect a USB modem to the HP touchPad? if at all
I am not a Touchpad owner but I am told you will need a Modem that is self powered, that is to say plugs into house power, the mini/micro USB port on the Touchpad is not powered. Contact any computer supply store for a Modem like this.
Sep 04, 2011 | HP Compaq 236076-001 Touchpad
Gateway 310 s won't recognize a cd
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
2. Click to select your computer as the location for the scan.
3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2.
Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
2. Expand Universal Serial Bus controllers.
3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
4. Click the Power Management tab.
5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
6. Repeat steps 3 through 6 for each USB Root Hub in the list.
7. On the Action menu, click Scan for hardware changes.
8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3.
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
I am unable to use the bluetooth app in my laptop..the moment i open, it shows error 797 a connection to the remote access server was not made because the modem was not found.......please help me..........
This is for GPRS connection
You must have from your network provider: the internet access point name, your user name and password.
Download and unzip the attached file in a folder on your desktop
1- Disconnect the device from your desktop
2- On the Activesync icon on your desktop, open "Connection Settings". Uncheck "Allow USB Connection".
3- On your device: Go to "Beam" (in Settings/Connections), and uncheck "Receive all Incoming beams".
4- Then in Programs, click on "Wireless Modem". With the Connection type on USB, click on "Start".
5- Now, connect your device to the desktop. The "Found New Hardware Wizard" starts on your desktop. Click "Install from a specific location", then "Don't search. I will choose...", then click on "Modems", and "Have Disk..." and go to the folder where you unzipped the attached file.
The HTC USB Modem will be shown in the compatible hardware: click to install. Continue if you receive the alert of the software not passing the Windows XP compatibility test (Continue anyway). Finish.
6- Now, in Control Panel of your desktop, open "Phone and Modem Options". Select the "HTC USB Modem" and click on "Properties". In the "Advanced" tab type for "Extra initialization commands":
AT+CGDCONT=1,"IP","xxx","",0,0
where xxx is your internet access point.
Click OK to finish.
7- On your device (always open in the Wireless Modem program), click on Tools/Options. Check the Preset GPRS connections and write in the APN, your network provider internet access point.
8- Finally, on your desktop, go to "Network Connections" and click "Create a new connection". Choose "Connect to the internet", then "Set up my connection manually". Click "Connect using a dial-up modem", then give a name to your ISP. In phone number type *99#. Get username and password from your network provider.
Better keep a shortcut of this connection on your desktop for quick access.
Each time you want to use your device as a modem:
Disconnect your device
Disable Activesync from your desktop by unchecking the "Allow USB connection"
Open Wireless Modem on your device and push on Start (with the Connection Type on USB)
Connect your device, then dial from your desktop using the shortcut you created
PS: Remember to enable Activesync once you've finished.
Nov 16, 2010 | Computers & Internet
Got dynalink V1456VQE modem need to install please help how to
internal modem installing:
1.Switch off the power,and remove the power card from the cpu.
2.Get the cpu separately.
3.unsqrew the sqrews and open the system box
4.you can find the white color slot in the mother board.
5.fix the modem with that slot (Modem Board has the single cutting).it must be fitted with the PCI slot.Slight press down.
6.then ON the system,
Start->all programs->control panel->system
->Hardware->Device Manager
now you can see more items on screen,also you can found the modem which you have installed.
Your new modem is ready to use...
7.If your modem came with cd,then insert the disc in cd/dvd drive .Gently Installed the cd...
8.Then Restart the computer.
External Modem Installing:(We do not need to open the system case)
Type 1:(Using Ethernet Cable)
1.Insert the ethernet cable(RJ 45) in the modem,and connect the other end of the cable to cpu.
2.insert a power adaptor in the modem jack.
3.insert the phone line in modem phone jack.(RJ 10)
4.On the system and Modem.
5.Your new modem is ready to use...
Type 2:(Using USB cable)
1.Insert the USB cable in CPU,and connect other end of the cable to modem .
5.You must install the driver software cd came with your modem
6.Restart the computer
7..Your new modem is ready to use...
Feb 13, 2010 | Dynalink (V1456VQH) Modem
Sir/Madam I am having a BSNL Broadband connection with a SIEMENS C2110 Modem.But I can't install the USB Driver.I have tried every possible ways,but to no avail.I can't even run the installation...
Hello Dear,
It is the problem with your OS and not with your modem, You need to repair or reinstall your Operating System agin to get the modem install.
Thanks
Feb 02, 2010 | Computers & Internet
Usb modems will not work see's modem but will not complete driver install. Even if you manually update. Tried 2 modem's
check to make sure that your USB ports are working properly. Best thing is to hook up a usb mouse or usb keyboard.
if it recognizes those and installs the drivers properly then you know your USB ports are fine, at this point you know that its got to be something with the modems, either they are not compatible or the modems are bad.
Try a brand new usb modem and make sure whatever type of usb port that the modem requires is the type of usb ports you havve on your server.
Aug 11, 2009 | Dell PERC6/E SAS Adapter for Dell...
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Multitech Systems MultiModem ZBA (MT9234ZBA-USB) Analog Modem Logo
Top Multitech Systems Computers & Internet Experts
Michael Vincent Cruz
Vladimir Frolov
Larry Fostano
Larry Fostano
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
