Question about Cozy (VCR502A-BM) Heater
My rennai convector 417 makes clicking noise but wont ignite
  • 45 Answers
Check spark is jumping a gap across the gas flow check thermocouple
Posted on May 25, 2011
2000 lincoln town car light control module wiring diagrams
You don't need a wiring diagram ,what you need is a scan tool that will pull codes from the LCM , an LCM Parameter Identification (PID) Index ! Checking codes first !
LCM Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By Action B1312 Lamp Headlamp Input-Short to B+ LCM REFER to Section 417-01 . B1334 Decklid Ajar-Short to Gnd LCM REFER to Section 501-14B . B1340 ESC Tone Input Request Short to Ground LCM REFER to Section 501-14B . B1342 ECU-Defective LCM REPLACE the LCM. REFER to Section 419-10 . TEST the system for normal operation. B1352 Ignition Key-In-Ckt Failure LCM GO to Pinpoint Test C . B1359 Ignition Run/Acc Circuit Failure LCM REFER to Section 211-05 . B1462 Seat Belt SW_Ckt Failure LCM GO to Pinpoint Test B . B1485 Brake Pedal Input Circuit Short to Batt. LCM REFER to Section 417-01 . B1555 Ignition Run/Start Circuit Failure LCM REFER to Section 211-05 . B1569 High-Beam-Short to B+ LCM REFER to Section 417-01 . B1577 Park Lamp Input-Short to B+ LCM REFER to Section 417-01 . B1581 Panel Dim Increase Input Circuit Short to B+ LCM REFER to Section 413-00 . B1585 Dim Panel Decrease Input Circuit Short to B+ LCM REFER to Section 413-00 . B1676 Battery Voltage Out of Range LCM REFER to Section 414-00 . B1687 Dome Lamp Input Short to B+ LCM GO to Pinpoint Test D . B1689 Autolamp Delay Input Circuit Failure LCM REFER to Section 417-01 . B1691 Autolamp Delay Input Circuit Short to B+ LCM REFER to Section 417-01 . B1695 Autolamp ON/OFF Short to B+ LCM REFER to Section 417-01 . B1873 Turn Signal/Hazard Power Feed Short to Ground LCM REFER to Section 417-01 .
Aug 12, 2016 | 2000 Lincoln Town Car
How do I convert a Rinnai Convector 417 flueless space heater from LG to NG?
with a conversion kit sold at the place that sells the heaters .
Apr 14, 2015 | Rinnai Heating & Cooling
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
How do I clean inside my rinnai convector 417?
The owner's manual at http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
Evening, Rinnai Convector 417 - the two flames on the right hand side panel are on - heater tries to light but switches off before igniting we have cleaned the filters - seems to be no spark
There are about 8 reasons why this is happening. Rater than going into each and every one, I have included a link to an Owners Manual, that under the Troubleshooting Sections (pages 12 & 13) it will provide you with the scenario and how to solve the problem. This manual may not be the exact same one as your heater, but they all work the same and have the same problems.
http://www.rinnai.us/documentation/downloads/RHF265-1091X0101_202FTA_265FTA_Manual.pdf
Hope this helps you to further troubleshoot and solve the problem.
Apr 27, 2011 | Rinnai Heating & Cooling
Shuts house circuit breaker off shuts house circuit breaker off
Breakers can get worn out and trip when they didn't earlier.The wires to the breaker can work loose over time.
Apr 24, 2010 | Heating & Cooling
Need to convert rinnai convector 417 gas heater from propane to natural gas, are the nozzles available?
Rinnai New zealand conversion kit number, R1852.
VERY complicated - get a qualified gasfitter to do it.
Jun 10, 2009 | Rinnai Vent Free Gas Heater/
RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
May 06, 2009 | Heating & Cooling
Cozy (VCR502A-BM) Heater Logo
114 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
