Question about Tricity Bendix AW1400W Front Load Washer
Motor won't spin, with flashing "End" light and 3 beeps
Mine broke last week. No matter which programme I chose, the drum just not turning. It does water intaking, then drain the water, with the "End" light flashing, and makes 3 beeps, repeatly. I thought it would be the brushes, since the drain pump is working, only the motor is not spinning. Took a brush out and found it has loads left, which means it is not the brushes then.
Any thoughts? Please, I desperately need help in fixing this machine! Thank you guys!
    Problem Solver:
  • 16 Answers
This should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
Posted on Dec 20, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My machine does not spin the clothes out like it should. I have to put on spin again before the clothes come out like they should. What could be the matter?
mine was doing that too...eventually you'll end up replacing the drain pump motor cuz one day it won't **** out any of the water and blink and beep and stop on ya hope this helps!
Sep 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Classique dishwasher, 3 weeks old. turned it on and chose dishwashing programme. Started ok but then beeping sound and has gone to pots programme. Light jus flashes. Stopped. Cannot reset. tried turning it...
You have a warranty, call the seller and ask how to use the limited warranty you have on the machine. As long as you didn't do something to the machine, they will usually just give you a different one to save on service calls in the long run, just get an exchange, I don't see any reason they won't do it.
Sep 01, 2011 | Dishwashers
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Jun 20, 2011 | Miele W435WPS Front Load Washer
My AW1400W does not working
mine does this ..alot. its usually limescale buildup or other obstruction in the connector to the drainage pipe under the sink. One time it was limescale in the main filter down on the bottom righthand side. a real pig to get out and to clean!
Aug 15, 2008 | Tricity Bendix AW1400W Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
585 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
