Question about Hotpoint Aquarius WF000 Front Load Washer
My washing machine wont open at the door and has no power to it. i have checked the fuse on the plug and it is fine.
  • Hotpoint Master
  • 1,525 Answers
Hello go to this web site it will show you www.espares.co.uk hope it helps
regards
shaun
Posted on May 24, 2011
Bosch washing machine logi xx7 no power cant open door. fuse ok
Check power at outlet and make sure you are getting power to the machine. If you are then the board on the machine may have had a surge and burned out
Sep 25, 2016 | Bosch Washing Machines
How do I open washing machine door
check mains going into mechine
Feb 27, 2015 | Miele Washing Machines
Have a GE Select washing machine that won't start or operate ? Can you help ?
Hello there and than you for choosing fixya
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Feb 06, 2011 | Washing Machines
I have no power to my machine. the plug is in and the the fuse box is fine in the house and still the machine wont turn on. i started a load of laundry and it lost power befor it finished.
If the lid switch is defective, your washer may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't work until you replace the fuse.
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer won't turn on, do I need a new door switch?
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 27, 2010 | Washing Machines
MAYTAG MAH5500BWW
No power
Lid switch
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wont start
No power
Lid switch
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Sep 20, 2008 | Washing Machines
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius WF000 Front Load Washer Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
