Question about LG HT503TH Theater System
I have an HT503 LG home theatre. I put a USB in the slot and now I cant get the dvd player back. The option doesnt even come up. How can I reset the system or get the dvd back?
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
SOURCE: dvd home theatre system
When I turn on my DVD it says "welcome to samsung dvd, no disk, protection, good bye" Why? What is wrong and how can I remedy it???
Posted on Nov 24, 2008
SOURCE: resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Posted on Jan 02, 2009
  • 4 Answers
SOURCE: DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Posted on Mar 12, 2009
SOURCE: My LG blue ray player is locked in region one.
have you tried resetting the unit
hold the power button for at least 5 seconds, this will force the unit to turn off.
turn it back on
unplug the power cord
wait at least 5 seconds
plu it back in
Posted on Jan 20, 2010
Lg ht503
The Manual for your LG DVD Home Ent unit says: Some DVD+/-RW, DVD+/-R or CDRW, CD-R cannot be played on this unit due to the recording quality or physical condition of the disc, or the characteristics of the recording device and authoring software" So If what you burn on your PC can be played on another stand alone DVD Player Recorder than I would say that the problem is just that, not compatible media. Codecs, Firmware Update, Recording software used and Region Code can play part in problems, just depends on how much you can eliminate yourself.
Apr 27, 2013 | Computers & Internet
My LG HT503 is locked in Bypass, I can not choose other setups as I could before. Can someone give me an advice?
When the theatre is in the standby mode press and hold STOP button on the panel (not the remote) for some time - it should UNlock
Dec 31, 2012 | LG HT503TH Theater System
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
I need to make my LG DVD Receiver HT503 region free
I need step by step instructions how to set up my home cinema LG ht503
May 17, 2009 | LG LST-3510A DVD Player/Receiver
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
I have LG dvd player connected to 5.1 home theatre system with 5 speakers......But only 2 speakers are working...theres no problem with home theatre, it works with all speakers when connectd to...
Please check the menu and enable 5.1 surrond option on and the dvd player dose it support surround if yes also check that u have connected the correct colour cable in correct palces..
thanks
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
HOmetech HT503 8 ohm speakers
WITHOUT ANY PROBLEM. THE SOUND WILL BE LITTLE SOFT BUT YOU CANNOT MAKE ANY PROBLE USING 8 OHM ON 3 OHMS AMPLIFIER
Nov 26, 2007 | HomeTech HT503 Main / Stereo Speaker
LG HT503TH Theater System Logo
399 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
