SOURCE: rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
SOURCE: E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Testimonial: "You were right! can you help mr with a P2 error code?"
