Question about Mongoose Cycling
CHAIN KEEPS COMING OFF ALSO CHANGES GEARS BY IT SELF
    Brigadier General:
  • 8,546 Answers
Posted on May 24, 2011
Testimonial: "THANKS"
How do I fix jumping gears on rear derailleur?
I also would check if the chain is not worn out. When the lenght increases the chain links, these also can make the chain jump. Put the bike up and rotate the peddles, while shifting gears and watch if the d?railleur moves fast enoug. Perhaps even the jumping is over, because the links are not pulled out.
for chain wear, check out this wiki. Bicycle chain Wikipedia the free encyclopedia
Mar 22, 2015 | Cycling
Chain keeps coming off
If the chain is tensioned properly then you may have a burr or burrs on the driver links. It makes the driver link to fat to fit in the groove of the bar.If you can fin the bad link or links grind off the burr. If they all have burrs it is easier to get a new chain.
Jan 27, 2014 | Craftsman sears 18" Chain Saw Chain (...
Timing chain replacement nterval
timing changes change is indicated by a rattly noise from the from of the engine. Most have a hydraulic adjuster that keeps the chain tight and if you do regular oil changes with quality oil then the requirement to change the chain would pass 200.000klm or about 180.000miles depending on your driving habits and what rpms you push the engine to
Aug 17, 2013 | Cars & Trucks
The chain keeps coming loose
If the chain keeps coming lose it can be down to a number of things, inadiquate oil to the chain, incorrect type of oil in the tank, poor quaility chain, worn sprocket and or guide bar.
May 14, 2012 | Garden
I ride a Cad3 R900. I love this bike. took it in recently for service and was convinced to put a larger back cluster on.(sorry I don't know the exact size) However now I cannot use top 3 rear gears on...
You woundn't be doing any damage. When you change the amount of gears you usually need a selector(on handlebars) that has the same amount of settings to be able to use all gears. Alternatively you can adjust the derailer to take the larger gears but you probably wont be able to use the lower gears-there's 2 screws on the derailer near the join of the 2 parts..1 changes the angle-the other changes the in-out setting.
I hope this has been helpful.
Aug 29, 2011 | Cannondale Cycling
My bike does not seem to shift gears should I be cruising as I shift or should I be pedaling
Your bike must not be the Cruiser pictured - that's a one-speed bike. So here's a general description--- For gear changes on multi-speed bikes, where the chain has to move between different size sprockets, the chain must be moving in order to shift. So, yes, you have to be pedaling, but it works best if you pedal very lightly - so that the chain is moving, but is under very light pressure. On the other hand, if you have a 3-speed bike where the gear changes take place inside the hub of the rear wheel, the wheel should be moving, but the chain should not - so you should be coasting to change gears.
Jun 23, 2010 | John Deere Nirve Model Cruiser Bike
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Chain keeps coming off rear cogs when you stop pedaling, and when you change gears , Have had bike to bike mechanic twice to fix the problem to no avail ! Alignment of rear derailer has not solved the...
Coming off which side ? - outside toward the frame member or inside to the spokes.
You should avoid using the small chainring and small cog combination which is silly on the one hand, damaging to the drivetrain and usually results in a lot of slack chain dangling down between the derailleur and the cranks.
Here are instructions on how to set the limit screws which determine the physical end limits where the derailleur can lead the chain.
http://parktool.com/repair/readhowto.asp?id=64
Apr 07, 2010 | Cycling
Cycling Logo
267 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
