Question about Sony Televison & Video
Sony kdf-50e2010 its four years old and i have never replaced the lamp so i know i have used up the 8000 hours of the lamp's life and more. the lamp indicator stays red and the power indicator blinks red 3 times i have checked the door to the lamp and it is hitting the switch. i am not sure what to do next i would love any help
  • 373 Answers
Take the lamp out and inspect it. Look down the bulb at the root of the filament stem and look for any bubbling of the glass there. If so it is bad. It can be bad like this even if you don't see any broken glass inside the blub. The best place I found to get a lamp with housing is pureglare.com
There could be other problems but the lamp is first place to start. Then consider the ballast or the thermal switch which is on the top of the lamp housing. The ballast could be a pill to change...a lot of disassembly and re-assembly. But it supplies the voltage to light the lamp. To test the thermal switch you can take one wire loose from it and jump with an alligator jumper clip from wire to wire temporarily. The thermal switch has two wires connecting.
Posted on May 24, 2011
Sony kdf 50e2010 cant see picture in daylight
these are not designed to light to be directly on the screen--failing that being the issue the model indicated uses a lamp for the light source.
If another model and older set may require simple cleaning---confirm with comment button here that is is Sony and the model number is.....
Mar 23, 2012 | Televison & Video
Tv stays on for a few minutes and then goes off;after 30 seconds,blue light flashes,and tv goes on again;
If it is Sony Grand WEGA KDF-55XS955 tv then it needs lamp replacement as existing lamp in tv has reached at end of its working hours life and causing this problem.
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it. Lamp replacement procedure is easy and written in user manual.
Required lamp part number for tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL2200U
Available in Sony Accessories Store for $200
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Nov 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Once you get the "Your lamp is nearing the end of
Hi, it is not. The manufacturer can only approximate on the life hours that lamps can last(usually 6000 to 8000) but it is not a rule. It's best to start shopping for one when the notice appears, that way you'll have a spare replacement ready when it does quit.
Oct 30, 2010 | Sony KDF-50E2000 50" HDTV
Replaced the projection lamp, it is still saying that it is ending reaching the end of its life, Is there a reset button?
  • 1
    The procedure may vary from Sony model to model. These procedures are for Sony Rear Projections only. For other models, please consult your manufacter's website. All rear projections have the option of reseting the lamp hours. This helps since you will know how many hours your last lamp ran for. Normal lamps should run between 5000 to 8000 hours.
    Try the following procedure:
    Please be cautious when entering service mode. Following the information below and you will have no problems.
  • 2
    Enter service mode by pressing Display, 5, vol +, Power On.
  • 3
    Proceed to the Option-E screen by pressing the 2 or 5 button
    Option-E 0 0
  • 4
    Change data to 1 using the 3 button on the remote
    Option-E 0 1
  • 5
    Press Mute Enter to write data.
  • Oct 29, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Dark picture. Is a tube/lamp out
    It sounds like a lamp issue this lamp are rated for 6000-8000 life hours, that equal to 2-4 years avareage use so if your lamp is over 2 years then the problem will be the lamp
    I found the lamp you need make sure to buy the Philips be carefull with the generic lamps
    http://www.discount-merchant.com/SearchResults.asp?Search=XL-2200
    PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
    Oct 18, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
    I have a sony wega rear projection tv 42 inch and the standby botton the light at the front is on and when you try to turn it on the light trys to switch on it flashs both lights but nothing happens
    this could be a few things but the first places to start would be the lamp this lamps are rated a life span of 6000-8000 life hours of use the equal to 2-3 years of use so I think this is the issue at this point here is the lamp you need for a great price
    PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
    http://cgi.ebay.com/Sony-XL-2100U-XL2100U-XL-2100-XL2100-A-1606-034-B-Lamp-/120607314201?pt=LH_DefaultDomain_0&hash=item1c14c19119
    Sep 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
    My sony kdf-e42a10 lcd projection tv has good sound but for some reason the picture has gotten real dark, you can still see it barely, what could be causing this
    Cause of darker picture is lamp that has reached at end of its working life span and need to be replaced for brighter picture in tv.
    Replace lamp in tv to get problem solved.
    Thanks.
    Jul 24, 2010 | Sony (XL-2400) Projector Lamp for...
    Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
    Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
    Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
    How do i replace the lamp on the kf 50we610
    Sorry, they misinformed you!
    On this model Sony the lamp access is located to the side of the set. You will see a small hook you can push down with you finger releasing the lamp outer cover. There might also be 1 screw to remove the panel.
    Now you will see the lamp inner cover. It has a grey handle in the middle of it - to dark to see down there, get a flash light. Remove this by turning it counter clock wise. Now pull the cover out. Note the chip on the one corner of the cover. It can only fit back the same way.
    Now you will find a slot you can fit your finger into. Pull this down and pull the old globe out.
    FYI - If the globe has burnt leaving a white discharge behind inside the globe - great, your TV is healthy. If it blew with a black discharge I would suggest you take a hear dryer on cold setting and blown as much dirt from inside the globe cavity as possible. also try not to switch your TV on and off to often. If you leave the room and you know you will be back within a hour, leave the set on. You will much easier reach 8000 hours of globe life. 8000 Hours is possible, I have seen it before.
    Now place the new globe into the socket. Just push it in until you feel the locking mechanism engage. Return the inner lamp cover. Turn the grey lever clockwise.
    Now all that is left is to clip the outside cover into place. Put the screw back if there was one.
    If you have to remove more than 1 screw - you have gone too far.
    P.S There are certain lamps that does not have a clip, but rather a HEX key screw. You will receive this hex key if you bought a genuine Sony globe in the box.
    Good luck.
    Jul 21, 2009 | Sony XL-2100U Projector Lamp for...
    Televison & Video Logo
    118 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
