Question about Tricity Bendix AW1400W Front Load Washer
My AW1400W does not working
Mine broke last week. No matter which programme I chose, the drum just not turning. It does water intaking, then drain the water, with the "End" light flashing, and makes 3 beeps, repeatly. I thought it would be the brushes, since the drain pump is working, only the motor is not spinning. Took a brush out and found it has loads left, which means it is not the brushes then.
Any thoughts? Please, I desperately need help in fixing this machine! Thank you so much!
Mine does this ..alot. its usually limescale buildup or other obstruction in the connector to the drainage pipe under the sink. One time it was limescale in the main filter down on the bottom righthand side. a real pig to get out and to clean!
Posted on Aug 25, 2008
SOURCE:
Why won't my Bosch nextt 100 series washer add water to to rinse?
First you must check water in drum. If is inside drum water than could be problem with drain water. If is not, than is problem in phase "intake water". In this case could be problem with electro-valve for rinsing cycle or wiring between valve and programmer or electronic depending of appliances and finally electronic or programmer.
Dado
Aug 05, 2015 | Bosch Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Indesit WIDL126UK that never wants to stop!
did you ever get to the root of the problem >}?
mine is doing the same.
[email protected]
Sep 25, 2009 | Washing Machines
Tricity Bendix AW1400W front load. Water leaks onto floor (a lot). Hoses dry. Pump and drain hose OK. Running the program causes leak. Pouring water into soap dispenser drawer causes leak. Just pouring...
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Aug 17, 2009 | Tricity Bendix AW1400W Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Motor won't spin, with flashing "End" light and 3 beeps
this should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
Aug 15, 2008 | Tricity Bendix AW1400W Front Load Washer
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Jan 22, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
154 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Bobby G
Bobby G
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
