Question about Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher
Hi, I have a SMEG slimline dishwasher (model UKSTX4-1), and need to repalce the lower spray arm support duct. I was wondering how to remove the existing one? Do you need to access a locking nut from underneath?
  • jgmdavies May 24, 2011
    It's not the lower spay arm itself I need to remove, it's the connector (duct) that it fits into on the floor of the dishwasher. Once I remove the spay arms, it looks as if the duct should unscrew but I can't shift it to put the new one in
  • jgmdavies May 26, 2011
    The model in the video is not the same dishwasher I have, the arm swings from back to back while rotating. I can remove the arm but not the duct it slots into
    President:
  • 2,468 Answers
I believe on this model there is a locking tab near where it mounts down to the pump area,check for a tab under the arm that feeds the wash arm
Posted on Jun 01, 2011
  • danny Hendrickson Jun 01, 2011
    yes,isn;r there a locking tab by the floor of the tub that locks the duct
  • 4,323 Answers
Hi
In SMEG dishwasher to remove the lower spray arm, simply lift it up, pulling by the central part. Hope this helps... Please post back if you need ore information.
Daniel
Posted on May 24, 2011
  • Daniel Scott
    Daniel Scott May 24, 2011
    Check this video, just an example on how its done:
  • Daniel Scott
    Daniel Scott May 26, 2011
    Thanks for rejecting the solution....anyways to remove the spray arm you have to remove the nut....I know in the video the model was not SMEG but it was given to you as an example on how its done. After the nut is removed lift up the spray arm to remove it.
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in the country and have hard water. I am wondering if there could be a buildup of some...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My SMEG Dishwasher is not cleaning my dishes, I put the wash on and it cleans it but when I come to take the dishes out they are still dirty
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
75osrha
Oct 12, 2009 | Smeg 24 in. DWF612WH Free-standing...
How to remove lower spray assembly in order to clean water filter
There should be a plastic nut holding the spray arm. Remove the plastic nut and the spray arm should release.
Does this help you?
Vic
Jul 23, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Can't remove lower spray arm
the nut screws off counter clock wise.
Mar 18, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top spray not functioning in dishwasher
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Mar 09, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Spray arms don't spin on Smeg DWF 410 ss
Remove he wash arms and visually check for obstructions in the holes where water sprays out if any number of these are blocked it will happer the turning of the arms
Jan 21, 2009 | Smeg 18 in. DWF410SS Slim-Line...
Smeg 18 in. DWF410SS Slim-Line Free-standing Dishwasher Logo
133 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
