Question about Cell Phones
My Vtech corded phone adapter was by mistake plugged into a wall light switch for the past year .... now the Call Display is not lit up properly? Any suggestions?
    Sergeant:
  • 145 Answers
Change the adoptor which is easily available in the market
Posted on May 24, 2011
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
No dial tone, no caller id but red light is on
First unplug the phone. Remove the phone cord from both the phone and the wall. Then replug in the phone cord. Then re-plug the phone. The phone should be unplugged for at least 1 minute. Make sure to check the connections of the phone cord for debris/damage. If this doesn't work then check a different phone in that telephone line it could possibly have been disconnected in the wall or under the house or even at the switch box on the corner by a neighbor having changes to his service.
May 13, 2011 | Vtech 5.8GHz Analog Cordless Phone
My phone vtech dect 6.0 has on the display not registered.
My Dear:
Yes, that is normal for all cordless phones. they are really just a radio that sends a signal from the base/charger to the cordless hand set. when the power goes off the base does not work at all. Go buy yourself a cheap corded phone, and when power goes off plug it into any wall phone jack and then you can make calls.
May 06, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I have a new printer and it has no power
Plug the printer straight to the wall power outlet, bypass any surge device or power strips. If still no power. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. With the power cord still attached to the power adapter and the other end plugged in to the wall power outlet, the LED, found around the silver contacts on the adapter, should lit green. If it's not lit, make sure the power cord is properly secured in it. Otherwise, you're looking at a defective power adapter. If that's the case, I suggest you contact Lexmark Technical Support and request for a new power adapter for your printer. They can send you one for free. If it's lit, plug it back in the printer in the right position. If it won't automatically power on, press the Power button. If that doesn't help, the problem might be on the printer itself. Again, if that's the case, I suggest you contact Lexmark Technical Support. Hope this helps.
Jun 23, 2010 | Lexmark X3650 Printer
The display went out on my AT&T 84354dx. What do I do to get it back?
Hi Check the power brick in between the phone and the wall socket for your phone connection. The brick provides power to the display. make sure there is power green LED should be lit and the cables should be plugged in properly
Dec 18, 2009 | Avaya Definity 8434DX Corded Phone
The display screen on my Avaya 8434DX isn't working. Any ideas?
check that the power brick is plugged in to a wall socket with power. The brick is gray and sits in between your phone and the phone socket. It inserts power for the display. ensure that the green LED is lit on the power brick and cables are plugged in properly. If the power brick is faulty contact your maintainer to get a replacement
Dec 14, 2009 | Avaya Definity 8434DX Corded Phone
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Question:
Answer:
May 05, 2009 | Lands Phones
Can't hear caller
This problem often results from a defective handset cord--check the handset cord by switching it with a good one. If that solves the problem, replace the cord. With a portable phone, substitute a transmitter from another telephone--replace if necessary.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
