Question about Frigidaire Refrigerators
Freezer side freezies up every 4/5 days causing other side not to cool
    President:
  • 2,468 Answers
Remove the rear panel inside the freezer,if theres frost on this panel then defrost the evaporator coil inside here and then you need to check the continuity of the defrost heater and thermostat on the coil as its not defrosting properly
Posted on May 24, 2011
Refrigerator on my side by side Amana not cooling
check to see if you have a the fan running in the freezer, if not replace fan. if fan is running do you frost on the back wall of freezer, if so defrost by opening door for 3 to 4 hrs. turn back on and if frost returns in 3 to 4 days call for service
Jan 07, 2012 | Amana Refrigerators
Freezer side works well but the refrigerator side is not coolong, Milk spoils in 4 days
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | GE GSH25KGRWW Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
Refrigerator
  • 4 hours is not enough to defrost it. also it will just frost back up if it has a bad heater, defrost timer or thermal switch.
 it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermal switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge/freezer not cooling anymore despite increasing settings
  • if is not cooling at all (completely warm/ room temperature) then it could be the start switch on the side of the compressor.
if is a little cool but not cool enough, Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  3. bad thermo switch in freezer
Jul 10, 2008 | GE Refrigerators
Cool but not Cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is only cool, everything melting
  • possible causes:
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
