Question about Lavazza LAV80114 Stainless Steel
I have the Lavazza point. Yesterday I was making my coffee and water starting leaking from the bottom. Today, I went to make coffee and no water or coffee came out and water leaked from the bottom. When I tried to press the water button, no water came out. HELP!
  • 710 Answers
I owe this solution to one of our experts, Seldemseen: "there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round."
He replaced his seal with one from his local hardware store.
Good luck to you,
I hope this helps. If it did, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 25, 2011
I have lavazza expresso pointe machine. I put in cartridge and select cup size and water keeps going. It doesn't stop so cup overflows and ends up just water flowing thru
need to remove the back cover, which has a few screws in the bottom left corner is a round and white plastic device that is said meter. Disconnect hoses from it and open it. Clean it well and then close it and put in place. Should be fine!
Jan 06, 2014 | Lavazza Espresso Point Capsule Machine
Lavazza 2100
You could avoid this problem by flashing water out without any capsule in. In anycase is a simple problem, you need to disasemble the machine and remove the head shower and wash it from dry coffee liquid which is blocked all the showers holes.
Jun 22, 2012 | Lavazza Espresso Point Capsule Machine
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
Can't get a full cup of coffee
First, you should not be using your espresso machine as an american coffee maker. It puts way too much pressure on the components of the machine. The standard cartridges are made to do 1.5 - 3.0 ounces of espresso. should you want to make a longer cup of coffee you need to get the aroma point gran caffe cartridges, lavazza code 427. this will enable you too get the longer cup of coffee without putting the added stress on your machine. Also it sounds like your machine mighy have a problem with the volumetric device. are you getting water in the capsule ejection drawer? should you want service you should call 781-393-2929. we are an authorized lavazza distributor and repair center.
Oct 09, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza coffee maker does not recognize that it is filled with water
A small water sensor needs to be replaced, you can pick one up, from sovrano, or a supplier pretty easily,
Apr 29, 2008 | Lavazza Espresso Point Capsule Machine
Leakage when filling espresso cup
I had the same problem, there is a O-ring seal between the heater and water feed...U have to remove apprx 8 allen screws on the top of the heater plate, remove the wiring connectors from the heating element and overload sensors and the heater plate romoves from the attached bottom plate. The seal is located on the center nipple and is apprx 1/8" round. Replacing it with a seal from the hardware store corrected my problem...GOOD LUCK!
Mar 10, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza LAV80114 Stainless Steel Logo
88 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
