Question about Vacuums
I have an aerus electrolux guardian canister vacuum. The cord was damaged but the retraction winder is still fine. I have ordered a replacement cord but I have no idea how to remove the old cord and install the new one. Am I over my head?
  • Vacuums Master
  • 11,800 Answers
The winder is activated by a coil spring located in a drum. The drum transmits the power from the wire with 2 circular contacts. To replace the cable you must dismantle the case to access the drum, take the spring pressure out carefully as to not let it spring outside the case (2 meters of a flat spring band are a nightmare to put back in) , gently pull the drum out as to not damage the circular connectors then uncoil the cable and unscrew its ends from the contact blades. Refitting is the opposite.
As you can see it's not a complicated job, but if you do it wrongly it can mess up your day. You should decide if you are skilled enough to do it.
Posted on May 24, 2011
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
Cord will not retract
Tilt the front of the vacuum to a 45-90 degree angle. Gently tug and release cord until it retracts.
If this doesn't work, repair or replacement of the cordwinder is needed. For this the vacuum needs to be taken to an authorized Aerus Electrolux store.
http://www.aerushome.com/storelocator/
Jan 31, 2011 | Electrolux Lux 5500 Canister Vacuum
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
How do I open the canister of the Aerus Electrolux Lux Guardian? I need to replace the retractable cord mechanism. Aerus won't help me.
This will not be difficult to open, however, inside may scare you.
Remove your hepa filter cartridge (if you have one)
turn the machine over.
Undo the 6-8 screws there and pull the bottom off.
you should see everything there. If you are careful, just remove the old rewinder, and replace with the new one.
Good luck.
Mark
Nov 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Broke cord reel on Lux Ren.
The only way is to replace the cord winder assembly.
Feb 20, 2010 | Electrolux Guardian Bagged Canister Vacuum
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
Is it the long type, 2 wheels on the back, one swivel wheel on front?
Aug 02, 2008 | Electrolux Vacuums
Power cord will not retract
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Dec 01, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
