Question about Sony STRDN1000 71 Channels Receiver
When I try to auto Cal. my speakers. i get an error code front 33. what does that mean and how do i fix it
    Brigadier General:
  • 8,546 Answers
RTFM (refer to the manual) Page 44.
None or only one one of the front speakers are connected (as detected by the microphone).
Register and download the it for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DN1000-Receivers-manual/id/23411ag516/t/2/
Posted on May 24, 2011
2005 fxsti diagnostic codes ? I have (from flashing engine light) 23, 32 & 33. can anyone tell me what they mean before I declare war on google ?
Each code has multiple diagnosis.
You'll need to figure which it is.
The codes mean the following (each code has more than one diagnosis)
23 = Front injector open/low
23 = Front injector high
32 = Rear injector open/low
32 = Rear injector high
32 = Alarm output high
33 = System relay contacts open
33 = System relay coil high/shorted
33 = System relay coil open/low
33 = System relay contacts closed
Jun 24, 2014 | 2005 Harley Davidson FXSTI Softail...
What's the actual meaning of DTC codes 41, and 58, for this vehicle?
the meaning of codes 41 and 58 is:
DTC - 41 Ignition control error
DTC - 41 MEM- CAL error
DTC - 41 Cam sensor sinal error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS System error
I hope this is helpful
Feb 18, 2013 | 1992 Buick LeSabre
How do I adjust speaker levels one at a time? Have problem going to each individual speaker. Manual is very confusing as well.
Which procedure needs re-interpretation?
Auto Cal on page 34?
Page 76 is the manual settings. You turn on the test tone. You listen and subjectively. I'd recommend leaving the Front L and R at 0 as you stake in the ground and adjust each other speaker to as close as possible to that level.
Feb 06, 2011 | Sony STRDH710
I had a unit installed 14 months ago. So far so good but just noticed an error code (33-limit fault). Is this something I can fix?
33-limit fault means high pressure in discharge side. May be your condenser coil is full of dust. clean it.
Dec 11, 2010 | Heating & Cooling
Have error code 33 on dash what does it mean 08 model r1
Error Code 33 means that there is problem an
Open circuit detected in the
primary lead of the cylinder-
#1 ignition coil.
• Open circuit in wire harness.
• Malfunction in ignition coil.
• Malfunction in ECU.
Hope this helps
Mar 02, 2010 | 2008 Yamaha YZF-R1
Need to know what codes 12 and 33 mean,thanks/93 chevy lumina,auto trans.
Code 12 is just a code telling you that you are in the diagnostic mode and it is working. Code 33 is a mass air flow error code. The computer is detecting mor air going into the engine then required at the detected rpm for more than 5 seconds. Could be caused by a faulty connection(wiring harness,ect) to a bad ECM(electronic control module) or MAF(mass air flow) sensor. Also the TPS(throttle position sensor) could be out of adjustment.
Dec 29, 2009 | 1993 Chevrolet Lumina
I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Nov 29, 2009 | Sony STR-DH700 A/V Receiver
ERROR 12 - but all the speakers work. why?
The manual lists no error code 12. Check that all speakers are in the correct place in the room and that they are not out of phase (that on each speaker positive is connected to positive on the receiver and negative is to negative). Make sure that the mic is laying flat, and that the room is quiet. If using a sub woofer switch the speakers to small.
Jan 29, 2009 | Sony STR-DG500 System
Radio and cd player stoped working suddenly
the security on the radio has been tripped you need to take it to a GM dealer and have them run a code to unlock it CAL means calibrate
Jul 04, 2008 | 2001 Chevrolet Monte Carlo
Fax error code on Ricoh 2045
network errors, like the 15-03, that you are receiving, have to do with fax "forwarding". the errors are thrown because the proper destination, or setup of the destination, for the forwarded faxes, are incorrect.
personally, i have not seen any 15-whatever codes. all the codes that i have dealt with are 14-01, 14-09, and 14-33. please double check the code that you are getting, and check the settings on copier.
14-01 and 14-09 codes usually mean that the smtp server name is incorrect, or the administrator e-mail address has not been added to the setup of the machine. although, it is still possible to e-mail directly without the administrator address being programmed. fax forwarding canNOT work without it. hence, the codes.
14-33 code usually means that there is an issue with the folder destination that the machine is trying to send to.
Jun 27, 2008 | Ricoh Aficio 1035 Copier
Sony STRDN1000 71 Channels Receiver Logo
192 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
