Hello; i am trying to install my hp sanjet G2710 and i find this error: Errr 1904.Module C:\Program Files\HP\Digital Imaging\bin\hpqcxs08.dll failed to register. HRESULT -2147467259. I need your help. thanks.
    Problem Solver:
  • 12 Answers
This problem can occur when one of the following conditions is true:
  • The file is not installed correctly.
  • The file is corrupted.
  • Other programs, including memory-resident and anti-virus programs, are running and using any version of the file.
Register the File Manually loadTOCNode(2, 'workaround'); To register a specific file again in the registry, while you are working in Microsoft Windows, follow these steps:
  1. Click Start and then click Run.
  2. In the Open box, type the following command, and then click OK RegSvr32 filenamewhere filename is the name of the file specified in Error 1904.
You should receive a message that the file is now correctly registered. If this doesn't fix your problem then go to http://support.microsoft.com/kb/237294 for further options.
Hope that this helps!
HelpDeskMan
Please rate this and/or leave a comment. Thank you
Posted on May 25, 2011
In minecarft what does this mean: hs_err_pid#
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Jan 22, 2013 | Microsoft Corporation Xbox 360 Live...
From the HP Solution Center the following error message appears about scanning: Parsing error in file C:\ProgramFiles\HP\Digital Imaging\bin\hpqscloc\1033.xml
1) Go to C:\program files\HP\digital imaging\bin\ and check how many folders are there for HPQSCLOC .If there are only one folder for HPQSCLOC in that case don't touch the folder.
2) Go to command prompt
TYPE THERE "CD..." AND HIT ENTER
KEEP TYPING "CD." AND HIT ENTER UNTIL WE SEE C:\
WHEN C:\ COMES
TYPE THERE- "regsvr32 /u hpqscloc.dll"
We may get an error in vista which says module failed to load
Follow Step 3
3) Open cmd prompt
Go to C:\
Type there
"regsvr32 hpqscloc.dll on"
4) Download and install
http://www.microsoft.com/downloads/details.aspx?FamilyID
=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
http://www.microsoft.com/downloads/details.aspx?familyid
=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Try to scan
Or else follow step 5
5) Uninstall the imaging device and the solution centre
6) Download msicuu2 from microsoft.com
http://www.filewatcher.com/m/msicuu2.exe.189920.0.0.html
Run the windows cleanup utility
Delete AIO Scan from it
7) GO TO CMD PROMT
Then type CD programfiles\hp\digital imaging\bin
8) Type regsvr32 /u hpqscloc.dll
try scanning and check if it works or not
if not follow another step
9) Tried to uninstall the software
10) then install the software back
It will scan fine
Mar 26, 2011 | HP Office Equipment & Supplies
Help me fix a Parsing error in file C:\program files\HP\ Digital Imaging\bin\hp\qsclo\1033.xml.
In the following location there is a file called hpqscloc.dll. Right click the file and choose Properties.
Go to Version tab. What is the version of your dll? Mine is 120.0.26.58
Try double clicking the 1033.xml. Is there any error message when you do so?
Nov 07, 2010 | Computers & Internet
Failed Error During Installation. MSI.dot4wrp...Error Code 2753' Message Displays on the Computer in Windows XP and Vista
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
Sep 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hpqcutil.dll missing
Copy all the files in "C:\Program Files\Common Files\HP\Digital Imaging\bin" to "C:\Program Files\HP\Digital Imaging\bin".
Sep 01, 2009 | RCA CDS1005 Digital Camera
Scanning
"HP cue scanning flow component problem"
Run or double click on the "HPQDSCTC" file in:
C:\Program Files\Hewlett-Packard\Digital Imaging\Bin OR c:\Program Files\HP\Digital Imaging\Bin
This should resolve the issue and if the issue persists then completely uninstall and reinstall the software from HP's website.
Try this. If it does not work, it may be a photo program like Kodak or Adobe Pjotoshop that may be conflicting with the HP software.
Let me if it works or if not, do you have any of these programs installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 20, 2008 | HP Photosmart C6280 Printer
HP Photosmart Essential v3.0 and v3.5
Aug 31, 2008 | Cameras
HP C5180 scanner won't scan an image
I'm running Windows Vista 64bit Ultimate Edition. Have the C5180, all-in-one. HP Solution Center continually closed, saying No HP Devices Found. I completely uninstalled the printer software, using the install utility. Then, using Add/Remove Programs, removed all of the other HP software on my PC. Then deleted the HP directory (in program files x86), and removed the HP registry key under software in both HKEY_LOCAL_MACHINE & HKEY_CURRENT_USER. Then rebooted. Once that was done and back up, I reran the install utility, but this time I followed the steps below (from here - http://hpanswers.blogspot.com/2007/12/no-hp-devices-detected-hp-solution.html):
Click on next until you get the below three options
(i) Recommended
(ii)Custom-------------->Select This
( iii)uninstall
Choose the custom install and click on next, ****
At begining of the installation, It gives you to 2 options
I) Yes, Check for updates..........
II) No, I prefer to do it Myself--Select this option and click on next
Immediatley in the next window ,you will have long list of softwares with the empty check boxes beside them.DO NOT select(check) Hp update, check rest of them and click on next to continue the installation.
You will able to open the HP solution centre with No errors.
Additionally, I did the following 2 steps, that I mostly found here (http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897551&lc=en&dlc=en&cc=us&softwareitem=oj-54112-1&os=2093&product=1153481&rule=9653&lang=en)
Add the following files to the Trusted programs list:
hpqkygrp.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqscnvw.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqste08.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqtra08.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqthb08.exe , located in the C:\program files\HP\digital imaging\bin directory.
Open the following ports on the firewall utility by following the instructions provided by the manufacturer:
UDP ports: 161, 427 and 137
TCP ports: 9220, 9500 and 9290
Jun 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet pro L7580 all in one
Hello drking,
I feel your pain!! I have an HP Pro L7650 that behaves the same way. If you figure it out I would sure like to know how you did it. I hate these pickey little problems! Give me SMOKE anytime... I know what to do with that.
haMAR
Apr 01, 2008 | Office Equipment & Supplies
Computers & Internet Logo
504 people viewed this question
David Payne
David Payne
