Question about Siemens Dishwashers
We have just purchased an IQ100 SE26N250G Dishwasher and are having problems in setting the washing programme. We have followed the instructions in the leaflet but the dishwasher will on wash on 40 degrees and cannot be cleared or changed to any other programme. Also, the information in the instruction manual that accompanied the dishwasher is not at all clear and is rather confusing as it shows that to clear an existing programme you simultaneously press and hold the 2nd and 4th buttons out of an array of 5 buttons, however our machine has 6 buttons and having tried a number of different combinations we are still unable to clear this programme and change to any others. There is no other information in the manual to advise on this. Can you please explain to us how to make these changes?
SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Posted on Feb 10, 2007
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
ngfam1
  • 639 Answers
SOURCE: kenmore dishwasher blinking lights
Dear friend,
ngfam at you service! happy to assist!
The blinking lights are called codes and this is warning you that there is a technical problem. Probably an electronic failure some where. This can only be diagnosed by a trained service tech!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
MNfisherman
  • 11896 Answers
SOURCE: De Dietrich dishwasher model DVF300JU2
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Posted on Jul 12, 2010
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
Do you have a user's manual
The manual is found here:
Bosch Order Management System LINK:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
You can also find these downloadable pdfs at this link (for your same model):
IU - Instructions for Use
SI - Short Instructions
In - Installation Instructions
PT - Programme Table
RP - Recipes
SP - Supplement
Jul 16, 2014 | Bosch 500 Series SHP65T55UC Fully...
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
How do i reset the cycle programme on my ADG 954 Dishwasher
Hello
Wait for five minutes if the motor stopped itself and has been stopped for less than 10 minutes. This occurs in the event of an overload. If this is the case, the dishwasher will reset itself in approximately 5 minutes.
Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
Repeat step 3. This will reset the dishwasher.
Aug 11, 2011 | Dishwashers
Some 1 gave my daughter a slimline zanussi dishwasher not sure what model it is but looks quite old. need a manual as the program numbers have faded and cant see them regards chris oh and its a aqua save...
If the model is correct then even without a manual the control set up is as follows.
From Lhs you will see on/off/ button next are the 2 lights top one is on/off and the bottom is for salt low light.The next button to the right is rinse and hold next Intensive 70 Degrees,next Normal 65,next Bio 50, next Quick wash 50 Degrees.To cancel a wash programme open the door and press the button for the prog. underway for more than 1 second until the corresponding light goes out.
The dishwasher is now reset and you can select a new programme.You can try this site for a manual.
www.appliancehelponline.com
Hope this helps.
May 27, 2010 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
MATSUI DISHWASHER MS160SL. IT STICKS HALFWAY THROUGH THE WASH PROGRAMME. IT IS NOT GETTING HOT. DONT KNOW IF ONE PROBLEM IS CAUSING THE OTHER IE IF THE ELEMENT NOT HEATING IS CAUSING THE PROGRAMME NOT TO...
I have the same problem and have found that it is caused by as you suspected a burned out heater element. they can be purchased on the web for £15.95 at partmaster .co.uk
Sep 23, 2008 | Dishwashers
Water pre-heating
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Dishwashers Logo
110 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
