turn WLAN switch on/off, and try again if it doesn't workscan for your network connection.
make a new connection.
and delete the old one
and try the new one.
ok sounds like you've pinched an o-ring in the trigger assembly. dissassemble the gun again and look for a torn or pinched o-ring. when reassembling the tool make sure you put some grease on the seals and other moving components to avoid these kinds of problems. if the o-ring is torn you can take the old one to most any local parts place and they will have a big box of o-rings and usually just let you match the old one with a new one and sell you what u need.
oh and it doesn't really matter what kinda of grease u use just dont use penetrating oil ( like wd-40 or 3-in-1 oil ) or it will soak into the seals and reduce the life of your seals, motor oil or any standard bearing grease should do the trick
My psp did the same thing. 1. Turn off psp. 2. Hold down R trigger while turning psp back on. This should take you to the M33 Recovery Menu. 3. Go to "Configuration" press X then go down to "Use VshMenu" press X so that it is Disabled. This should fix it. Go up to back then down to exit. If this doesnt work or if it does work please comment back to let me know. I like to know that people actually read my posts. Thanx. Gonzo Dacompo
First of all try hold the right trigger if a recovery mode pops up go to usb mode and hit X. hook it up to ur computer and then run psp deluxe and tell it what drive ur psp is and then do what they tell you to do and set dcmenu as left trigger and start it and then trun off turn back while u hold left trigger! if a menu comes up with 4.01 m33 do that!\\
hold the on button and right trigger for around 5 seconds at the same time. This is the only way to access recovery mode. If doesn't work consider sending it in to sony tech support. sorry
try useing recovery mode, hold the R trigger and turn off the power button, then switch the power button back on while holding the R trigger ,that dont work try taking the battery out for some time...
