Question about Toshiba Satellite A10 Notebook
Power of The Fan is working fine, also the room temp is about 60 F. If I let the machine charge for 3 hours it works for a while but it powers of without notice. If I try to turn the machine on again it starts loading and then goes of again. Thanks
    Sergeant:
    Champion:
  • 322 Answers
Right i no what your saying but it is deafinatly over heating sound like your heat sink needs a clean? if your care full you can do it your self rother than pay some one ells to do it it not hard just renove battery and on the machinr arrows show you wear the screws are located i did mine with a paint brush a artis one so why your in there give it all a brush out
Posted on Aug 17, 2008
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
My vt60 winw cooler doesnt cool , it will show the degrees you want to set it at then few seconds later it goes back to the room temp. of 76...also makes clicking noise to start compressor then again a...
Sounds like the compressor is frozen - sound you hear is the clixon a special sort of resettable fuse on compressors. When they do not start or overheat, it kills the power - when it cools power is restored until it reheats again and .......................
Use ammeter to confirm this - it will show a much greater than normal current draw.
Apr 22, 2014 | VinoTemp VT-60 Wine Cooler
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
It looks working fine at in door and fan is working. but comp is not turn on.
Check your temp setting is minimum 3 degree less than room temp for cool. Check the power in condenser unit. If not, problem with thermistor. You have to repair/replace the PCB. Thanks.
Jun 01, 2011 | Heating & Cooling
GE GSS25QGMC-WW refrigerator is runnig, but not cool or freez. When I unplus power for 30 min to an hour and plus power back on. The compressor is runnig, cooling about 12 hours. After that I hear the fan...
What is the internal temperature set to? If the fan is running it sounds like you have the temp too warm. It's not going to be cooling on 1-3 (sort of cold not really).
Set temps as far "cold" as possible, wait a about 3-4 hours, check it. If you continue to have issues, you need to have it serviced by a repairman.
Mar 20, 2010 | Refrigerators
No water in bucket after running 8 hours. Very clean, no lint or dust anywhere! All settings on the top are correct. Used to work fine and then just one day it stopped completely. Thank you for your time...
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 07, 2009 | Soleus Air 25-pint Dehumidifier
Won't turn on
The unit in your back yard is the outside half. The one that blows room temp air is the inside half.
The outside half is not working. No compressor, no fan. That is a problem with the power. You will find the bad parts very close to where the power wires go into the outside half. It might be a bad relay that connects both the fan and compressor to the power. It might be a 3 terminal capacitor. It might be burnt wires.
Jul 24, 2008 | Carrier 38CKC042 Air Conditioner
Battery back up is limited to 1 hour only
Did you do a full cycle charge when you got the Laptop? When you buy the Laptop you have to use the computer on battery till the battery dies and then charge battery for 12 hours and you repeat that another time. Most likely your battery it is damaged. Maybe you call the company and they might replace it for you.
Jan 16, 2008 | Acer Aspire 3680 Laptop
Toshiba Satellite A10 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
