Question about Canon NP 6050 Copier
Hi i have a problem of paper jam in the satck bypass area i try to fix whit the operator`s manual but i can`t fixed so how you can help me or what i can do it thanks
Actually u hv not putted ur pblm correctly...
paper is jamming in ur machine but fm which tray u r taking paper...
n e way ...
1..if paper is comming fm down trays (i.e. 1,2,3,..or4) , try to clean the Pickup rollers of rubber material (at down side to the duplex tray or upside to the each tray) with some water and smooth cloth
2..if paper is comming fm bypass section then ur bypass pickup roller must be cleaned like above, or it must be replaced...
....try this and then also if not solved then place ur question again in detailed..
bye
Posted on Sep 13, 2008
Can not copy two sided.paper always jam
Check for some obstruction in the paper path where the paper stops. There can also be paper cuts in some of the sensor arms that may be giving hesitation delys csusing the jams. Jam codes in service mode will also help isolate the problem to a more specific area.
Jun 17, 2011 | Canon NP 6050 Copier
E10 falt 4050 cannon machine
check main motor, motor control board, check if paper pick up unit is jammed or fixing is jammed any kind of moving part jam can cause error e10
Dec 26, 2010 | Canon NP 6050 Copier
Paper jam for canon copier np 6050
It s very old model throw out it
Oct 15, 2009 | Canon NP 6050 Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
Paper jams in machine does not come out into trays
Any number of problems.....the most simple is that could the paper size is set incorrectly (either size and/or orientation) so the paper is not where the machine "expoects" it to be -check your tray settings. Otherwise, it could be dirty/worn rollers, blocked, or dirty paper sensors, fuser problem (depending where the paper is. The bottom line is....if you have the tray set correctly, then the solution to the problem will require technical intervention
Jun 09, 2009 | Canon NP 6050 Copier
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
Paper pick up problem
hi,try to clean feed rolls,sensors.clear any misfeed sheet from paper supply area.send me a result.
thank you.
Jun 01, 2009 | Canon NP 6050 Copier
NP 6050 Languge
how to fixed canon np 6050 copier because i dont have manual book
May 03, 2008 | Canon NP 6050 Copier
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
123 people viewed this question
old marine
old marine
