Question about Hotpoint WMA74 Front Load Washer
Hotpoint wma74 washing machine fills with water then does nothing will not run drum or spin
  • Hotpoint Master
  • 1,527 Answers
Hello it sound like the brushes on the motor could be the cause 2 plastic blocks sit either side of the motor these are made of carbon and wear down can cause the motor to stop working also the other causes could be interlock on the door and module control board hope it helps
regards
shaun
Posted on May 24, 2011
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Drum will not empty
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 28, 2011 | Hotpoint WMA74 Front Load Washer
My hotpoint wma74 front load washer makes a very loud thumping noise on the spin cycle ive got a feeling it could be the dampers but would like some more info please, ive run a the cycle empty and there...
It does sound as if at least one of your dampers are gone. Unplud the appliance from the wall, take the back cover off and see if there is any movement when you try shift the drum. If there is a lot of play on one side, that damper is likely gone.
Dec 12, 2010 | Hotpoint WMA74 Front Load Washer
How do i fit the drive belt on a hotpoint wma74 washing machine
Hook the belt over the motor shaft and feed it onto the drum pulley as far as it will go,hold it in place on the pulley with the aid of cable tie clips, then rotate the inner drum anti clock wise by holding the inside of the inner drum. This will draw the belt onto the pulley and the cable ties will snap as the drum rotates.
Mar 04, 2010 | Hotpoint WMA74 Front Load Washer
We have a Hotpint WMA74 - water gusting out of powder/liquid compartment at top when spins - have changed drain pump - but still happens - can you help?
It sounds like you have a partial blockage somewhere..
Remove rear panel.
Remove large black hose onto drum.
Check and clean filter inside hose.
Remove drain hose, and check for restriction here as well.
Please rate my solution.
Thanks.
Nov 17, 2009 | Hotpoint WMA74 Front Load Washer
Does not spin
either a belt or the motor brushes are shot.
Sep 30, 2009 | Hotpoint WMA74 Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Smelly drum
run a load with no clothes, hot water and a gallon or two of bleach and less then 1 drop, very small amount of dish detergent. the dish detergent is used as  surfactant (makes the bleach stick to the interior walls)
run an extra rinse cycle to make sure you get all the bleach out before putting clothes in.
Jul 04, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
182 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
