the pc could not recognize your web cam, try to plug out your usb web cam and blow or wipe the usb of your usb webcam. also try to plug it in to other usb port of your pc. if nothing happens, maybe the web cam it is the problem. and just to make sure that the web cam your using is the problem, try other usb web cam to see if its working on your pc. if the other web cam works on your pc, the web cam your using is damage, and if the other webcam is also not working, the usb ports of your computer is the problem. thank you for choosig fixya. if you have other question regarding to this problem, just post it.
HOw do you want to connect it USB o wireless .If its USB i can help you ...If you properly plug in your USB on the computer and to the computer and nothing happens , Ill be advising you to used a clean paper or a dry cloth try to clean the area where you plug in the cable to the computer and acble itself makesure the ports is clean , try other ports if still nothing happens .In case still no go , used another USB .try to test it on another computer if that USB chord is working on the other computer possibly the USB on your computer is not working ....Hoe it help thanks
Look at the USB ports, this sometimes can be a problem with a grounded USB port (2 or more of the USB pins in the port touching each other) sometimes this can happen with USB ports when an item is put in the wrong way round. If no joy then this can also be a problem when the internal CPU heat block has too much pressure on the CPU.
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You'll want to verify your computer recognizes your usb ports.
In device manager, look to see that you don't have anything with an exclamation mark, question mark, or red X on it. Make sure you have the usb ports listed under Universal Serial Bus controllers. If nothing shows, your usb ports may be dead. Depends on the age of your computer and what might have happened to them.
Device manager- right-click My Computer and go to properties, then select the hardware tab.
This happens to my ditty quite often. When it does happen I plug it into the USB port and press the reset button on the Ditty until the computer recognizes it.
