Question about HP PSC 2355 All-In-One InkJet Printer
I keep getting the message cartridge jam on my hp psc 2355. A paper jam was pulled out of the front so I know this is the cause but how do I fix it please?
  • our_fam May 24, 2011
    Tried that already - thanks though - A paper jam was removed from the front (the cause) I just don't know how to rectify it. Any ideas?
  • HP Master
  • 1,591 Answers
It's not saying carTridge jam, it's saying CARRIAGE jam. Something is stuck under the heads.
unplug the power from the unit, and try to manually move the heads off to the left side, checking for paper under the head as you move it over.
Check the head docking area on the right as well.
Plug the unit back in and everything should be fine once everything is cleaned out.
Posted on May 24, 2011
  • Norman Skinner
    Norman Skinner May 24, 2011
    It's possible that during the jam removal that the calibration strip was pulled off - or even worse - broken. In either of these cases, it's usually best to simply replace the unit.
    Without pictures, it's simply not a repair that's easy to direct via phone or chat or messages like this. I did tech support for HP for quite some time, and HP's policy on a broken or dislodged calibration strip under warranty was to replace the printer.
    Check your warranty...if you don't mention the paper jam issue, and the unit is under warranty, they will replace it or send you a voucher for the cost of replacing the unit including local taxes.
    No warranty - but thanks for the info.
My hp psc 2355 keeps on sayin CARRIAGE JAM
Hey
I gues this video in youtube sloves your problem
please let me if you face further problems
Thanks Anil
Jun 14, 2010 | HP PSC 2355 All-In-One InkJet Printer
Cannot print - keep getting paper jam message - after pressing cancel button, paper keeps feeding into machine w/ paper jam message again
Hi
try cleaning the paper jam first
check out the following link,this should help you a great deal
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=us&lc=en&dlc=en&product=422000
Jul 14, 2009 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Open Door. Clear carriage jam, and then press Enter
Sounds like you have a jam. Open the back of the printer and checl for any paper large or small. If there is no paper, just opening the door and closing it may get rid of the message. All it takes is a piece of paper the diameter of a pea to send a signal that there is a paper jam. After yuou have finished close the door and push enter to let the printer know you are finished. See if this helps. I don't think it has anything to do with the ink cartridges. It sounds more like something stuck causing the jam. Be sure not to have anything like a staple attached to the paper you are printing on to. A speck of dirt could casue a jam message too.
Aug 28, 2008 | HP PSC 750 All-In-One InkJet Printer
Psc 2355
check if there is a back door where you can access from there the rollers and check for any paper stuck , turn on printer and go to DEFAULT setting on the menu . hope it works
Apr 18, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sep 21, 2007 | HP PSC 2355 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
407 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
