Question about Maytag Refrigerators
Freezer working fridge hot - Maytag Refrigerators
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dandy 8.8 fridge not working but freezer does
freezer works but fridge wont cool
Aug 29, 2008 | Freezers
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
External Surfaces of Fridge/Freezer are hot
That is normal, refrigerators work by removing the heat from the storage area, thus making it cold. This heat has to go somewhere. Most of it is blown out the back but some escapes through the sides of the fridge.
Dec 28, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
