Question about Dimplex CS3311 Compact Heater
I HAVE 2400 WATT DIMPLEX BUH24T FLOOR ELECTRICAL HEATER APPROX 20 YEARS OLD WITH FUSED 3 POSITION WALL SWITCH. I AM REPOSITIONING THE HEATER AND NEED TO CONFIRM THE INTERNAL WIRING FOR THIS SWITCH. THANK YOU
    Brigadier General:
  • 4,736 Answers
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
Posted on May 24, 2011
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
Went to switch on fire switch blew up i have changed fuse in plug thats all ok so i think the triple switch is blown .
To purchase a new 3-way rocker switch, contact Dimplex Tech Service 1-888-346-7539.
Hope this helps and thanks for choosing FixYa.
Sep 22, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
What type of bulb is required for the mcn20 dimplex fire thank you
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have got an electric fire Place that blows out hot air, well after about 5 mins it stops blowing out hot air and it blows out cold air, can any one help me fix it?
More than likely, the heater element is overheating and the overload switch is turning it off. It could just be a case that the heating element needs cleaning. As they do become clogged with dust and lint, because they take in cool air at floor level, heat it and send it back out. You didn't mention who the manufacturer of your electric fireplace is, but they all work just about the same way (badly, most of the time). Turn OFF the Master On/Off Switch, unplug the fireplace from the wall and leave unplugged for 12 to 15 minutes. Now, would be a good time to clean the interior, if you want to under take it. Plug the heater back in and turn the Master On/Off switch to the On position. Turn ON and set the heater control. If it returns to normal operation, the problem is solved. If the unit continues to have to be reset (if it's a Dimplex) turn the Master Switch Off, unplug the unit and contact Dimplex USA, Technical Service at 888-346-7539 for more information.
Hope this helps solve the problem.
Mar 17, 2011 | Heating & Cooling
The heater does not work, no heat
The relay to the heater coil is probably bad. Depending on how old your unit is will determine if it's worth repairing. Typically, this problem seems to occur after 2 to 3 years. Usually caused by a build up of dust and lint on the heater coil. Often time, the heater switch also plays a roll in this. Check out the Dimplex website for trouble shooting this problem.
Jan 25, 2011 | Dimplex CS1205 Electric Compact Heater
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex CS3311 Compact Heater Logo
371 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
