All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want to change them back as folders..
  • 93 Answers
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
Posted on May 24, 2011
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
  • Shortcut Virus Remover is the best solution I found.
  • A 100% free simple application.
You can download it from this link - Shortcut Virus Remover
Place it in your pen drive and double click to run.
Press Enter to confirm its process.
That is all.
Shortcuts will remove and your data will be back in a second.
Posted on Oct 19, 2014
Can't find pictures in internal memory
If you can connect the camera to your PC via a cable, normally USB, to browse the contents of the camera's internal memory then try simply to do a search on the camera's 'drive' for .png, .jpeg or .jpg, .bmp or any other filetype that your camera would use.
Your PC should be able to find any files using those file types and display them. From there you can copy or cut and paste them to a location on your PC's hard drive.
You may have to make sure that your computer has Show Hidden Files and Folders turned on under Folder Options.
Normally, a camera saves all videos and pictures in a folder called DCIM, even on internal storage.
Jul 05, 2012 | Kodak EasyShare Z740 Digital Camera
Tip
How to Download Music to a Memory Card?
Downloading music onto memory cards allows you to conveniently transport and store your digital audio. Some personal computers come equipped with built-in memory card readers. However, external devices still provide download capability for those who do not own memory card-ready computers. In either case, the drag and drop process allows you to store your favorite music onto memory cards.
Instructions
  1. Insert the memory card into an external memory card reader or device associated with the memory card, such as a PDA.
  2. Connect the external memory card reader or device to your computer using a USB cable. Insert one end of the USB cable into the USB port on the external memory card reader or device. Insert the other end of the USB cable into the USB port on the computer.
  3. Wait for the computer to recognize the external memory card reader or device. You will access the external memory card reader or device as if it were a drive in your file manager. Skip Steps 1 through 3 and insert the memory card directly into your computer's built-in memory card reader if applicable.
  4. Open the file icon for the memory card reader or device to view its file contents as a folder.
  5. Open the folder containing the digital audio file you wish to download to the memory card.
  6. Drag and drop your desired digital audio file into the memory card reader or device's open file folder.
on Mar 12, 2011 | Cell Phones
I cant access any of the folders in my camera memory stick when I connect it to the pc with the USB. Its a 2GB . All the folders have a shortcut icon on them and when I try to access them...
Start off by running a virus scanner on that memory card making sure its clean, take out the memory card and put it directly into the computer using a micro drive to remove all your pictures from it, if you do not have one then you will need to download all the drivers and software for your camera to be able to connect to it and retrieve everything
Jun 27, 2011 | Computers & Internet
My memory card is showing shortcuts inside.. all folder changed to shortcuts.. n i m unable to open this.. pls suggest me answer
This is one VIRUS. Please Scan that sandisk with any antivirus. just you can use Kaspersky.
The manual procedure to see all the fiels is:
1. Connect the USB drive
2. go to command prompt. Run-> cmd
3. goto sandisk drive
by default c:\> prompt appears. type the drive letter with colon.
c:\> E: (if E drive assigned to your sandisk)
you can see in mycomputer: drive letter may be e: or f:
4.After getting that drive as prompt. like e:\>
Then type these commands.
attrib -s -r -h *.* /s
attrib -s -r -h desktop.ini /s
attrib -s -r -h autorun.inf /s
del desktop.ini /s
del autorun.inf /s
rd recycled /s
rd recycler /s
rd $recycled /s
5. Then goto My computer. you will find the folders and shortcuts also
please remove the SHOTCUTS only...
This will helps you .,
Jun 17, 2011 | SanDisk 1GB microSD Memory Card
My memory card in nokia 5230 are lock and i forgot the password...how can i open my memory card?
Plug the card into your computer - you'll have to have a memory card reader for that (or find a computer that does).
Open the memory card within Windows.
Find the SYSTEM folder.
Inside the SYSTEM folder, look for a file named MMCSTORE.
Open the MMCSTORE file, that will contain your password.
Jun 14, 2011 | SanDisk 2GB microSD Memory Card
I have Sony DSC-T90 camera. I think it's memory card is virus infected. When i attach my camera to computer to download pictures then only shortcuts of the folders are displayed. I can view the...
Have you tried removing the memory card from the camera and inserting it directly into the computer's card reader or any other card reader?
May 20, 2011 | Cameras
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Delete autorun.inf and that reappears. there also a folder called recycler that also reappears....
the folder named recycler is harmless..but the file autorun.inf is parasite..we can remove that using a software named "autorun eater"
and it is available free
http://www.softpedia.com/progDownload/Autorun-Eater-Download-85585.html
Jan 02, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sudden problem with my card... please help!
Can you access other folders on the same device?
If so, copy the contents of those folders onto your computer,
and burn a CD-R or DVD-recordable disk.
If _none_ of the folders are accessible, then use 'www.google.com' to search for "recover digital storage memory cards".
There is software that reads, page-by-page, and can "rebuild"
the table-of-contents, after reviewing all the pages in the volume.
Apr 06, 2009 | Kingston 2GB Secure Digital Memory Card
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Computers & Internet Logo
268 people viewed this question
David Payne
David Payne
