Question about Vehicle Parts & Accessories
MY JEEP'S SECURITY SYSTEM IS GOING INTO THEFT MODE WHEN I GO TO START IT,IT RUNS 10 SEC THEN SHUTSDOWN.IT DOES IT AT RANDOM,AND ALWAYS AT THE WRONG TIME.ANY IDEAS?
  • 625 Answers
There has to be an issue with your key; if no remote starter is installed. If you have an immobilizer bypass interface installed for a remote starter, it could be interfering with the manufacturer key.
Posted on May 25, 2011
Why does the anti-theft light stay on?
There is a problem with the system an there is a DTC - diagnostic trouble code stored in the body control module !
The vehicle theft deterrent system is designed in order to prevent vehicle theft by disabling the fuel injectors unless the lock cylinder is engaged by the correct mechanical key. The theft deterrent system uses the following 4 components for theft prevention:
The lock cylinder
The ignition switch
The body control module (BCM)
The powertrain control module (PCM)
When starting the engine, the PCM searches for a password from the BCM through the Class 2 serial data circuit. If the password is not recognized or not present, the PCM will disable the fuel injectors. Two modes of tamper detection are provided:
No password received
The engine will start and stall quickly. SECURITY telltale will flash on the instrument panel cluster (IPC) and then stay ON steady.
Incorrect or disable password received (More than 3 invalid passwords are received)
The engine is disabled for at least 10 minutes and the SECURITY telltale will illuminate solid on the IPC during the 10 minutes.
After the vehicle has passed theft detection, the PCM will continue normal operation
Ignition Switch
The mechanical key and lock cylinder is located on the steering column. The main electrical switching portion of the assembly is separate from the key and lock cylinder. The VTD portion of the ignition switch is the Passlock?"¢ cylinder.
The Passlock?"¢ lock cylinder is a locking cylinder that turns a magnet past a stationary hall effect sensor. When turned to crank, the hall effect sensor is latched which applies a fixed resistance to the Passlock?"¢ signal data circuit. The voltage measured by the BCM on the Passlock?"¢ signal data circuit is the Passlock?"¢ data value.
Body Control Module (BCM)
The BCM compares the Passlock?"¢ data value to a value that it has stored in memory. If the values match the BCM sends a password via the class 2 serial data line to the PCM.
Powertrain Control Module (PCM)
When the PCM receives the correct password, the PCM enables the fuel injection system, allowing the vehicle to operate correctly. The PCM may allow the car to start and quickly stall during a failed theft condition.
If the BCM does not receive a Passlock?"¢ data value, the BCM will enter a short tamper mode. During this mode, the VTD system will not allow the car to operate for 4 seconds.
If the Passlock?"¢ data value is incorrect, the VTD system will enter the long tamper mode. In the long tamper mode, the following actions will occur:
The THEFT SYSTEM indicator will flash.
The fuel injectors will be shut off for approximately 10 minutes.
Although the vehicle may start, the engine will quickly stall due to a fuel cut-off.
In the event of an open in the serial data communication between the BCM and the PCM or a failure in the Passlock?"¢ lock cylinder, the following actions occur:
The VTD system will become fail-enabled if the car has already passed theft for that ignition cycle (i.e. the engine is running).
The PCM or the BCM may set diagnostic trouble codes (DTCs).
The THEFT SYSTEM indicator will light continuously.
The PCM will become fail-enabled for future ignition cycles.
If a failure occurs when the ignition is off, while the VTD system is not fail-enabled, the PCM will never receive a valid password, and will not allow vehicle operation by disabling the fuel injectors. An this system can set 6 DTC'S
DTC B2947 Security System Sensor Power CKT Low DTC B2948 Security System Sensor Power CKT High DTC B2957 Security System Sensor Data Circuit Low DTC B2958 Security System Sensor Data Circuit High DTC B2960 Sec Sys Sensor Data Incorrect but Valid DTC B3031 Security System Controller in Learn Mode DTC B3033 Security System Indicates Tamper
May 21, 2015 | 2000 Chevrolet Cavalier
2000 pontiac grand am ,car cuts off on road .security.light comes on and you wait 5 min .sec.light goes out car will crank and go 2 to 10 miles .then problem starts over again.in code history in obd2 tool...
Here's a trouble shooting guide.Trouble Code: P1632
Theft Deterrent Fuel Disable Signal Received
Possible Causes:
Perform the Powertrain Onboard Diagnostic System CheckPassword Learn Procedure - Attempt to start the vehicle (leave the ignition "on"). The Theft System telltale will flash for 4 seconds and then remain "on" for 10 minutes. Theft System Learn Mode will display Disabled on the Scan ToolTurn the ignition "off" after the Theft System telltale goes "out".Repeat steps 1 and 2 two more times. After the Theft System telltale turns "off" on the 3rd key cycle, and Theft System Learn Mode will display Enabled on the Scan Tool, attempt to start the engine. Once the engine starts the password is learned.
Oct 27, 2012 | Cars & Trucks
1996 jeep gcl and pcm is locked in theft mode. runs for 3 seconds and stops. Scanned vechicle and everything is ok but wont come off lock
Hi James:
Just keep in mind that the 1993-1998 Grand Cherokee was called "ZJ Series", so they have the same device and systems; in your 1996 Jeep Grand Cherokee Anti-Theft System is equipped with Vehicle Theft Security System (VTSS).
VTSS system monitors vehicle doors, hood, liftgate and ignition. If an attempt is made to enter or operate vehicle without proper disarming of system, vehicle horn will sound, headlights, taillights and parking lights will flash, and engine will be prevented from running.
The following wiring diagram and electronics circuit contains detail schematics of The ZL's Jeep Grand Cherokee Anti-Theft System. HERE you will find interconnection between electronics parts of the system such as body control module, auto headlamp light sensor. VTSS led, driver door module, passenger door module, cylinder lock switch, junction block, power distribution center, and grounding.
Additionally, Is request your email account to send this diagram (big scale) and other details in PDF format where you will learn also how the Vehicle Theft Security System works, removal, installation, testing and troubleshooting procedures.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer. Keep in touch.
Thank you for using FixYa, have a nice day.
Jan 31, 2012 | 1996 Jeep Grand Cherokee
I NEED TO BE ABLE TO DRIVE MY CAR SO HOW DO I DISABLE THE THEFT DETERRENT SYSTEM TO MAKE IT RUN CORRECTLY I DONT HAVE ORIGINAL KEYAND THE IGNITION IS DRILLED OUT HAVE TO START WITH SCREWDRIVER THE CAR...
the theft system is part of the main computer, you will need to change the ignition lock and get a key to remedy the issue, unfortunately there is not an alarm kill
Sep 21, 2011 | 2000 Saturn SL
1997 chevy malibu anti theft system how do I fix this problem The car won't start I believe the car is in the anti theft mode
The late-90's GM Passlock system (e.g. 1997 Malibu, Regal, Impala, etc.) has a part around the ignition tumbler that goes bad and no longer reliably detects the valid key. In that situation, the "Theft System" light will slowly flash and the carburetor is cut off so the engine won't start. The time-out on the system is 10 minutes - you don't have to do anything, you don't have to disconnect the battery, the key can be out of the ignition -- it's just a time delay. After 10 minutes, the light goes out and you can try again (but if the key is again not detected, the light will start flashing again and you have to wait another 10 minutes)
Someone else, who had this problem, told me to remove all other keys from my keyring. The weight of the other keys pulls on the ignition key causing the key to be unreadable. It has been 7 weeks since I have been doing this and have not had a problem
Sep 08, 2011 | 1997 Jeep Cherokee
I have a 1999 Oldsmobile allero and I am having trouble with the theft lock, randomly my car will not start and then my security light will start flashing and I have to wait for about 15 min for the light...
You are experiencing GM passlock security system. Yours is starting to fail. When the system gets old it fails to communicate with all the parts of the system that need it. When the communication is broken, the car goes into anti theft mode and and turns off the starter and/or the injectors. After ten minutes it trys to connect the communication again, this is why it will work after a while. Go to this link, it has a ton of info and some ways to bypass this system so it will never happen again.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jul 26, 2011 | 1999 Oldsmobile Alero
My trail blazer 2006 wont start and it has a light on of a car with a lock what does this mean heeelp please as soon as possible emergency
You have now experienced GM's terrible anti theft security system. These systems are known for failing and will cost you an arm and a leg to fix. Anywhere from $350 - $700 plus labor. Most mechanics wont even touch these "PASSkey" security systems.You'll have to go to a Dealer mechanic. The good news is that you can bypass these systems permanently. And you're vehicle is one of these lucky ones that CAN be bypassed. This link should help you find what you need and help inform you of how this system works.
http://vatspasslockpasskeysecurityhelp.yolasite.com/ TRAILBLAZER 2002 2003 2004 2005 2006 2007 2008 Effected by Passlock/PASSkey Failure. tayjoejoe_17.jpg
Jul 11, 2011 | 2006 Chevrolet Trailblazer
My car is stuck in anti theft mode and I cant get my car to start
The problem is your Vats security system. This causes the car to either "not start" or "shut down" while running. (depending on the system) If the security light flashes, i guarantee that this is what the problem is. 1st trick, turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start.
Cheap fix:
----- http://vats.likeabigdog.com/
----- Bypassing the key
Never worry again fix:
----- http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites
Jan 12, 2011 | 2001 Pontiac Aztek
2000 Alero - Internal Security system malfunctioning. Sometimes (randomly) when I try to start the car it will not start and the red "security:" light flashes. I have to wait 10 minutes while the key is in...
The vehicle theft deterrent system is designed in order to prevent vehicle theft by disabling the fuel injectors unless the lock cylinder is correctly engaged by a mechanical key. The theft deterrent system uses the following 4 components for theft prevention:
• The lock cylinder
• The ignition switch
• The body control module (BCM)
• The powertrain control module (PCM)
When starting the engine, the PCM searches for a password from the BCM through the Class 2 serial data circuit. If the password is not recognized or not present, the PCM will disable the engine. Two modes of tamper detection are provided:
After the vehicle has passed theft detection, the PCM will continue normal operation.
Passlock™ Lock Cylinder
The Passlock™ lock cylinder is a locking cylinder that turns a rotating magnet past a stationary hall effect sensor. This action creates the Passlock™ cylinder data. The Passlock™ cylinder data is sent to the Body Control Module (BCM). The Passlock™ lock cylinder is interfaced with the BCM via a 3-wire connection:
• Power
• Ground
• Data
The Powertrain Control Module (PCM) is located on the lower left side of the instrument panel.
The PCM communicates with the Body Control Module (BCM) via serial data over the class 2 serial data bus, CKT 1807. When the BCM determines a passed theft condition, the BCM sends a coded password to the PCM. When the PCM receives the correct password, the PCM enables the fuel injection system, allowing the vehicle to operate correctly. The PCM may allow the car to start and quickly stall during a failed theft condition.
The following conditions may cause the PCM to enter a tamper mode:
• A bad timing cycle
• An incorrect password
If the BCM does not receive a password within a preset time window, the BCM will enter a short tamper mode. During this mode, the PCM will not allow the car to operate for 4 seconds.
If the password is incorrect, the PCM will enter the long tamper mode. In the long tamper mode, the following actions will occur:
• The THEFT SYSTEM indicator will flash.
• The fuel injectors will be shut off for approximately 10 minutes.
In the event of an open in the serial data communication between the BCM and the PCM, the following actions occur:
• The PCM will become fail-enabled if the car has already passed theft for that ignition cycle (i.e. the engine is running).
• The PCM may set the diagnostic trouble codes (DTC).
• The THEFT SYSTEM indicator will light continuously.
• The PCM will become fail-enabled for future ignition cycles.
If a failure occurs in serial data before the ignition cycle, while the PCM is not fail-enabled, the PCM will never receive a valid password in order to enable the continued use of the fuel injectors.
Your best bet , take to a qualified repair shop .
Aug 12, 2017 | 2002 Oldsmobile Alero
Aftermarket anti theft system problem
Found the problem - it was not the security system - it was an internally shorted battery. Replaced the battery and the car is fine.
Oct 09, 2009 | Ford Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
265 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
