I have a samsung AW08ECB8 I have been using it for the last 2 weeks and it was working great. 2 days ago it stopped putting out cold air. It is running fine just not cold. Can this unit be recharged with coolant.
RepairUSA
  • 50 Answers
SOURCE: strange smell
Have you cleaned the evap coil? Most often smells come from the evap coil. A bleach type product used for cleaning will solve this problem. Thanks
Posted on Aug 10, 2007
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
  • 24 Answers
SOURCE: not blowing cold air, do u recharge this unit?
only after you find a leak. first u have to make sure if the compressor is running at all. condenser side spinning. if compressor is not working it will blow hot air if the condenser is dirty or blocked but then u would get a minute or two of cold air then hot. you have to determine its empty or what else might be the cause before you start dumping in freon.
Posted on May 28, 2009
  • 52 Answers
SOURCE: 2 weeks ago one of my units stopped working
sounds like the coils inside the air handler/furnace are freezing up. likely cause is the freon charge is incorrect (probably undercharged). it may have been correct when the tech did the work but some may have leaked out. it is slightly possible too that the system is overcharged. you should have the system pressure verified, and then have it checked for leaks.
Posted on Jun 18, 2009
SOURCE: My outside a/c condensing unit's fan runs, but
Start the unit and go outside to see if the insulated pipe is sweating or cold, hot air should be discharging from top of outside unit. Since the breaker is not tripping, my best guess is the compressor is not operating. You might have to replace the capacitor.
If you can hear the compressor operating, then most
likely needs refrigerant
Posted on Jun 17, 2010
Testimonial: "Thanks for providing some additional clues and methods to pin down what needs replaced. Now I need to determine whether the run capacitor or the other part, for which I can't find the name, is at fault, unless the compressor is bad."
97 Plymouth Breeze won't blow cold air due to freon leak.
Your AC system is a closed system, so the fact you have to put more Freon in, means there is definitely a leak. I would check it out with a mechanic.
Apr 26, 2015 | Plymouth Cars & Trucks
We have a propane tank outside to supply our range stove in the house for some reason the gas is not reaching the stove anymore , can it be the cold weather?
I would suspect the regulator might have iced and maybe if you poured hot water over it it would pass on thru system but be prepared to buy a new one if it doesn't .
Jan 13, 2015 | Cars & Trucks
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Hello my air conditioner is not blowing cold air. It seems like only the fan is working. I set the temp to between 16-18 celcius and the temp that is showing is 28 celcius. Also is showing E5 on the ac...
What did they do when it was serviced?It sounds like there may be a leak if it does not get cold at all anymore.Although,lasting 3 weeks,depending on how much you used it,it would be a very tiny hole leaking.The other most likely suspect would be the thermocouple went bad.It senses what the temperature is,compares it to what you would like to be,and enables/disables the air conditioner accordingly.The E5 code I cannot look up right now because you did not list the make and model.If you post that,I will get an autolink to your answer and check it out.Greg
Nov 06, 2010 | Heating & Cooling
2 weeks ago one of my units stopped working properly. It got warm during the night even though I heard the unit running. I shut it off and called for repair service. They changed the thermostat and it...
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
A/C not pushing cold air and low coolant message "was" displaying
Make sure the AC FAN & RAD fan is operating properly. It sounds like u may be dealing w 2 problems. Start w the basics, ck the fans. When u put ac on fan should go on, rad fan works w temp of motor (mid range on gauge should activate)
Mar 31, 2017 | 2006 Chevrolet Malibu Maxx
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
